17K Mile Dealer Check
Unless the cam cover gasket was damaged it should have been reused along with the other parts as recommended in the Honda service manual. Hope that was the case.
Some dealerships replace all the seals and gaskets as a routine procedure to avoid any leaks and "comebacks" after performing the service. My dealer would have replaced these, but as I did the work myself, I reused all the camshaft cover seals. The left side began to seep just slightly so there is some logic in replacing them.
When I came in weeks before we discussed the gaskets, I lean towards replacing them and would rather pay now then spend my time coming back if they do leak, he said they could do either but was glad I wanted new gaskets.
My dealer said if they open the brake or clutch res. they use new gaskets as they do not want to have to pay for a new tank or plastic parts if the old one leaks. They said it does happen. So, even though I didn't see anything wrong with mine, I changed them when I flushed the brakes and clutch.
Photo First Check Engine Light Ever on a Bike doug1976 2 230 01-14-2026, 06:47 PM
  Check your clips! Gone in 60 3 627 07-01-2025, 11:27 AM
  Basic Maintenance: Daily Check rdprdp01 17 1,413 03-01-2025, 02:52 AM
  Time to check the air cleaner! The A-man 6 680 08-22-2024, 09:39 AM
  How To do your own 600 mile service the Ferret 163 11,213 08-10-2023, 07:42 AM
  Sound check what wrong tory_imp 3 427 03-30-2022, 12:33 AM
Last Post: 1973cb750
  Valve check? Phat Ham_imp 26 1,957 01-13-2021, 12:36 PM
  Oil level difference between check zirconxi_imp 29 1,877 06-27-2020, 09:11 AM
Last Post: redbirds_imp
  cam chain check max 0 191 04-22-2020, 08:26 AM
Last Post: max
  check engine light stays on, on my 2017 Houtman_imp 51 3,463 07-27-2019, 01:27 PM
Last Post: itstuantran_imp
