stupid question perhaps - oil change before/after valve check?
Is checking the valve clearance yourself all that hard really?
It depends on your mechanical aptitude. You have to remove so e parts, including the valve cover which covers the top of the motor, and a side cover, turn the crank until one set of valves are open, be able to feel the amount of drag on a feeler gauge rotate the motor until the other set of valves are open and again feel the drag on a different feeler gauge, and determine by those measurement if the valve clearance is withn tolerance or not.
If they are its pretty easy and you button everything up. IF not THEN it gets complicated.
I've had the cam cover off on my Nighthawk. Especially with a Haynes or Clymers I think most could do this and if everything is okay zip things back up. If not okay, I suppose you have to take the cam shaft off and replace shims or you could take it to the dealer then.
  Valve Adjustment Shims dave 13 708 07-28-2026, 12:49 PM
Last Post: MagnaRider
  Valve Adjustment and Camshaft Removal dave 5 633 03-21-2026, 04:49 PM
Photo First Check Engine Light Ever on a Bike doug1976 2 234 01-14-2026, 06:47 PM
  Valve Adjustment dave 6 865 08-29-2025, 10:46 AM
  Valve Cover Baffle lining ? bflint 6 945 07-26-2025, 11:27 AM
Last Post: bflint
  Check your clips! Gone in 60 3 633 07-01-2025, 11:27 AM
  Valve Adjustment Intervals CBRider_imp 32 2,970 04-21-2025, 02:24 PM
Last Post: Jurlie_imp
  Basic Maintenance: Daily Check rdprdp01 17 1,416 03-01-2025, 02:52 AM
  Time to check the air cleaner! The A-man 6 684 08-22-2024, 09:39 AM
  Valve Adjustment Tolerances - How Far Do You Go? dave 14 1,525 10-18-2023, 09:28 PM
Last Post: The Gecko_imp
