Guhl Motors and ECU Re-Map for DLX / EX with Idle Issues
Hi Beardy, believe it or not, but I replaced the battery in my bike today and the idle problem is cured! I am NOT saying that the new battery cured the problem because it is probably just a coincidence, and my idle problem has come and gone before, but I just thought I would let you know. I replaced my battery because I turned the motor off at a stop light last Saturday when I was tired of the 1,500 RPM idle, and it wouldn't restart (I push-started it back to life and rode home). A load test of the battery performed by the dealer showed it needed replacing. I'll keep you updated.
Maybe it's like a Microsoft computer, you need to do a full reset, every now and then, to clear bad memory and get back on track?
Sent from my XT1096 using Tapatalk
  CB1100 Idle speed instability problem ericlo69_imp 1,434 121,950 07-26-2026, 01:51 AM
  idle problem update 1973cb750 37 2,170 05-12-2026, 08:38 PM
Last Post: rdprdp01
  Idle a little rough and miss fire when revved johnnyH_imp 3 439 09-15-2024, 12:16 AM
  another idle thread Tom_imp 11 1,055 11-20-2023, 01:30 PM
  TPS Sourcing because of High Idle Obi-wan Kenobi_imp 38 2,849 09-14-2023, 10:08 PM
  Honda CB1100 Rough Idle Solution dickie1951_imp 56 4,529 09-06-2023, 01:36 AM
  High idle mattmcuomo@yahoo.com 7 704 10-29-2022, 11:09 AM
  Fast Idle Problem Solved Nachodaddy 17 1,561 10-08-2022, 09:18 AM
   Dutch's High idle thread DutchRutter 17 1,598 09-27-2022, 01:55 AM
Last Post: DutchRutter
  Another High Idle Problem emptysea 60 4,303 07-05-2022, 11:41 AM
