Valve Check/adjustment cost
I paid $446.88 for mine in July while my bike was laid up for the accident repairs, so $320.00 sounds like a deal to me.
Two ways to check valve clearance without opening the motor; If it starts with difficulty. If it runs rough near redline. A friend with a Triumph Bonneville did not have to touch his valves til 50,000 and again at 100,000 and he crossed the country many times and did not baby it.
(01-09-2015, 06:54 AM)nhawk7504_imp Wrote: Two ways to check valve clearance without opening the motor; If it starts with difficulty. If it runs rough near redline. A friend with a Triumph Bonneville did not have to touch his valves til 50,000 and again at 100,000 and he crossed the country many times and did not baby it.
...or use a crystal ball?
scnr Beer
Definitely get you valves checked at least. Tight valves are worse then loose valves. Not hard to do the check yourself
(01-08-2015, 08:26 AM)xNE0x_imp Wrote: Honestly $320 bucks doesn't seem like much since my buddy just dropped $1400 on his goldwing's valve check, oil change, and air filter.
in a similar vein, $200 to do just the valve check and 3 valves out of 4 on my CBR250..
There are only 4 valves AND the cams don't need to come out to change the shims.
Worth every penny after I tried to adjust them myself and knew when defeat was immenant... Like the mechanic said: "you need to be really careful when you get in there and swap out the shims"
Thanks!
(01-08-2015, 07:13 AM)Cormanus_imp Wrote: I have more that 31,000 kms on my bike. The valve clearances have been checked twice and have been within spec.
Same here. I have just under 27,000 miles (43,000 kms) on mine. I've checked them twice (8,000 miles and 24,000 miles) and they were the same both times and well within spec.
Pretty sure Pterodactyl would report the same result for his 42,000 + kms.
I checked at 8,000 and 16,000mi and in spec and consistent both times. $320 for a check sounds fair, if the mechanic is qualified and trustworthy. It's not a hard job (the check), but it is involved and time-consuming. There's a lot of equipment between the tank and the top of the engine that needs to be carefully dealt with.
Is the valve cover gasket of the re-useable rubber type or do you need a new gasket for the inspection?
  Valve Adjustment Shims dave 13 707 07-28-2026, 12:49 PM
Last Post: MagnaRider
  Valve Adjustment and Camshaft Removal dave 5 628 03-21-2026, 04:49 PM
Photo First Check Engine Light Ever on a Bike doug1976 2 230 01-14-2026, 06:47 PM
  Valve Adjustment dave 6 863 08-29-2025, 10:46 AM
  Valve Cover Baffle lining ? bflint 6 942 07-26-2025, 11:27 AM
Last Post: bflint
  Check your clips! Gone in 60 3 627 07-01-2025, 11:27 AM
  Valve Adjustment Intervals CBRider_imp 32 2,927 04-21-2025, 02:24 PM
Last Post: Jurlie_imp
  Basic Maintenance: Daily Check rdprdp01 17 1,414 03-01-2025, 02:52 AM
  Time to check the air cleaner! The A-man 6 681 08-22-2024, 09:39 AM
  Rear Brake Pedal Adjustment Gone in 60 12 1,141 04-04-2024, 08:18 AM
