Weak Idle / Stumbling in Gear
(05-16-2017, 12:20 PM)736cc_imp Wrote:
(05-16-2017, 11:17 AM)Cormanus_imp Wrote: The faster idling when cold is certainly normal. I think it runs at 1500 rpm for a bit before falling to 1100 rpm when it's warm.
So maybe the oddball high idle issue is a malfunctioning sensor causing the idle to stay up even when bike is warm? Where is the temperature sensor and has anybody tried replacing it?
The Engine Oil Temperature (EOT) sensor is located at the back side of the cylinder, near center, bottom. I replaced mine and it did not solve the idle speed problem. However, unplugging it made the bike run perfect (this is why I replaced it). When unplugged the warning light comes on, and the oil temperature light is on also.
(05-16-2017, 02:41 PM)izmash_imp Wrote: ive had this happen on a REALLY hot day in slow traffic bike has even stalled once but only when the bike is really hot.
I'd like bet it's the dragging along in slow traffic rather than the heat. That's when mine suffered, in any temp. Most others wth the low idle issue found the same.
I will change oil and change plugs and report back next week. It could be the low idle issue I suppose,but the bike does not stall completely. the idle will stay alive albeit not ideal.
Hi Linux, I had this issue before the high idle issue kicked in. Rarely did the bike actually stall, but the idle would struggle between 500-750 RPM and need revs to keep it alive.
Hopefully the oil/plugs change helps, but keep an eye on it. Could be your IACV going.
(05-16-2017, 11:20 PM)johnf514_imp Wrote: Hi Linux, I had this issue before the high idle issue kicked in. Rarely did the bike actually stall, but the idle would struggle between 500-750 RPM and need revs to keep it alive.
Jon: Were you able to pin point it / fix it? Or did it magically go away? Let us know your experiences.
Hi Linux, we have a thread on it here. This is my post recapping my experience, and you can check my post history for this issue:
http://cb1100forum.com/forum/showthread....#pid161586
had it happen in neutral after a small blip.
  CB1100 Idle speed instability problem ericlo69_imp 1,434 119,048 07-26-2026, 01:51 AM
  idle problem update 1973cb750 37 2,142 05-12-2026, 08:38 PM
Last Post: rdprdp01
  Idle a little rough and miss fire when revved johnnyH_imp 3 429 09-15-2024, 12:16 AM
  another idle thread Tom_imp 11 1,018 11-20-2023, 01:30 PM
  TPS Sourcing because of High Idle Obi-wan Kenobi_imp 38 2,757 09-14-2023, 10:08 PM
  Honda CB1100 Rough Idle Solution dickie1951_imp 56 4,317 09-06-2023, 01:36 AM
  High idle mattmcuomo@yahoo.com 7 700 10-29-2022, 11:09 AM
  Fast Idle Problem Solved Nachodaddy 17 1,516 10-08-2022, 09:18 AM
   Dutch's High idle thread DutchRutter 17 1,572 09-27-2022, 01:55 AM
Last Post: DutchRutter
  Another High Idle Problem emptysea 60 4,077 07-05-2022, 11:41 AM
