K&N oil filters .. known issue..FYI
Thanks for the post Ferret. About a month ago i was about to stop by cycle gear and grab one of the K+N filters to do my break in oil change. Ive used the K+N filters as well on my Yamaha Roadliner. Anyway, i saw a post here with someone who had a filter fail and blow oil out all over. I immediately said screw that filter, ill just go OEM Honda. I had 2 spares for my Yamaha in the garage, in the trash they went. Ill just use the good old OEM ones from now on. Cant believe the disaster the K+N ones are.
I suspect this all pretty hard on K&N, a company which has made lots of oil filters and had very few problems. That said, it is a significant failure for a motorcycle and one that puts the rider and others at risk. And it's a design fault that there's such a significant point of weakness on the filter. I'll certainly not be using them again.
The "chronology" section in the [url=https://static.nhtsa.gov/odi/rcl/2017/RCLRPT-17E044-7593.PDF]NHTSA safety recall report is interesting.
A change in manufacturer started the problem.
New ( cheaper ? ) supplier ???
  Help from the hive mind: Intermittent Starter Issue (2017) JRD 10 583 01-30-2026, 02:16 PM
Last Post: JRD
  Shifting issue Cormanus 31 2,454 05-15-2024, 12:59 AM
  Counterfeit Oil Filters 2017EX_imp 111 9,477 03-24-2023, 01:31 PM
Last Post: 808_rider_imp
  Arrow Slip on issue - stock gasket didn’t fit Ddawg1144_imp 4 481 02-21-2023, 07:51 AM
  Fuel reserve display issue Banksy_imp 2 299 06-29-2022, 04:37 AM
  Brake reservoir screw head issue satchit 72 5,450 04-24-2022, 11:55 PM
  Mechanical issue and hello again RickNRoll53_imp 8 686 12-16-2021, 06:46 AM
  CB 900C Custom Spark Issue goatman64_imp 3 385 11-27-2021, 07:11 AM
  2017 CB1100ex / Flat tire issue and save Senna02_imp 27 2,209 07-19-2021, 08:28 AM
  starting issue jigs_imp 12 855 06-06-2021, 01:51 PM
Last Post: max
