Rear Brake Fade?
I read all of your opinions and suggestions with interest. SportsterDoc - at the rear brake failure, I could not smell anything like the brake pads were hot. I had to ride a few miles to find a safe place to easily pull over. By the time I inspected the brakes, all parts were cool. The rotor color looks normal like the front rotors.
That bring me popgun’s suggestion to flush the hydraulics. I think this is definitely worth the effort, needs to be done anyway. Like Townie, I used the same simple technique to bleed the brake lines on automobiles. I assume I can do the same on the CB, both brake lines and clutch.
(07-18-2018, 01:15 PM)suhawk305_imp Wrote: I read all of your opinions and suggestions with interest. SportsterDoc - at the rear brake failure, I could not smell anything like the brake pads were hot. I had to ride a few miles to find a safe place to easily pull over. By the time I inspected the brakes, all parts were cool. The rotor color looks normal like the front rotors.
Yes, same technique.
The rotor would have cooled quickly, while moving.
If not discolored and no lateral run-out, then likely no harm to the rotor, if pads were applied.
I would flush the brake fluid just because of your scenario, which sounds a lot like an overheat situation. That fluid is used
Speed bleeders and a vacuum bleeder with your compressor :piece of cake !
(07-18-2018, 08:40 PM)Houtman_imp Wrote: Speed bleeders and a vacuum bleeder with your compressor :piece of cake !
I'd love to see a pic or explanation of that cake Smile
Well, it would be moist!
Update: I started by bleeding/flushing the clutch fluid the the old pumping, open/close bleeding screw, and the fluid bleeding stopped during the process. I must have accidentally introduced too much air in the clutch system. I got the shop manual out and saw that a vacuum bleeding tool was recommended. I got one from Harbor Freight that works with my compressor, as Houtman suggested. I was able to suck the air out and complete the flushing job.
I next did the the rear and front brakes, and it appeared that some air bubbles came out during the flush.
Took a short test drive and all systems worked.
I have to find out what “speed bleeders” are for the next time.
Good deal Suhawk!
(07-27-2018, 11:12 AM)suhawk305_imp Wrote: Update: I started by bleeding/flushing the clutch fluid the the old pumping, open/close bleeding screw, and the fluid bleeding stopped during the process. I must have accidentally introduced too much air in the clutch system. I got the shop manual out and saw that a vacuum bleeding tool was recommended. I got one from Harbor Freight that works with my compressor, as Houtman suggested. I was able to suck the air out and complete the flushing job.
https://www.speedbleeder.com/
Just installed 4 of these on my bike. Flushed and put new fluid in both brakes and clutch. It’s a one person operation and very easy. If you use search on the forum you’ll find several threads on speed bleeders.
  Rear brake pad replacement LongRanger_imp 39 3,851 05-03-2025, 10:45 AM
Last Post: Delphisa
  Rear Brake Pedal Adjustment Gone in 60 12 1,170 04-04-2024, 08:18 AM
   Rear brake pedal Mixagon_imp 28 2,242 08-06-2022, 07:29 PM
Last Post: Mixagon_imp
  Rear brake pad thickness. 17-CB-002 4 467 06-18-2022, 12:42 AM
Last Post: 17-CB-002
  rear brake question Crossfire_imp 12 920 02-18-2022, 03:02 AM
Last Post: bvictory_imp
  Rear brake rotor and new pads Sandhog_imp 13 1,029 01-08-2021, 04:51 AM
Last Post: ethan.phan613_imp
  Rear brake installation? White Dog_imp 9 859 07-27-2020, 02:48 AM
  Rear Brake "clunk" iogear99_imp 3 370 04-25-2020, 01:47 PM
  Rear Brake Help Needed White Dog_imp 21 1,638 10-01-2018, 07:10 AM
Last Post: Jim21680_imp
  Bike fell over, broke the front brake lever and bent the rear brake jlouis976_imp 24 1,795 09-14-2018, 12:35 AM
