Rear Brake Fade?
Late last week into the weekend, I attended my 45th college reunion in the North Country of New York State (Potsdam, NY). The trip was 325 miles through the Catskills and Adirondacks Mountains. What a beautiful ride on my CB! (Too lazy to dismount and mount the CB with luggage to take pictures.)
In the Adirondacks, you have several fantastic miles between towns to enjoy. A lot of times, I had the road alone to ride the curves and hills at my pace.
Problem encountered:
When I rode into an Adirondack town, I slowed down by downshifting and normal brake use. When I came upon an intersection, I had no rear brake and had to anchor the front brake so I wouldn’t rear ended a Harley trike. Luckily, I was going slow so I didn’t lose control of the CB, but the front end dive and slight tire skid got my heart rate up.
This is the ‘14 Standard, 3K Miles with the original hydraulic fluids. It was taken out of its crate and delivered to me during May 2017.
My thoughts:
Maybe sitting with my luggage bag strapped to my luggage carrier and back half of my saddle cause my right foot on the brake peddle to slightly push the brake peddle down.
Or, an air bubble(s) in the hydraulics worked its way out.
Note I occasionally pumped my brake peddle for a while and the brakes slowly came back. No further problems for the remaining trip there, or my return trip home was encountered.
While I was in Potsdam, I took my CB to the local dealer and left it. He pulled the cover, inspected the hydraulics and test rode the CB and did not find any problems. I asked him if the original hydraulics should be flushed, and he said no. He advised me to occasionally test the rear brake while I was driving. I went to pay him and he said no charge, I left a tip.
Any thoughts? Does anyone else experienced a problem with the brake peddle being pressed while riding? I usually use the gearing more than brakes when riding curves and hills.
[Image: 6cba8a3dbd089a8ae77bc83ed0133b40.jpg]
When this happened, how hot was the rotor?...that would verify or dispute your foot slightly on the brake pedal theory. Although I would expect to be able to smell the pads dragging.
At least 2 members (IIRC) had problems riding their rear brake. At least one overheated the rotor and warped it and, obvously, had to replace it.
Your bike is 4 years old. Brake and clutch fluid should be replaced every 2 years. Doesn’t matter if it was riden or sat in a crate.
Just because your dealer says the brakes are ok doesn’t mean they are. At least 4 members, including me, had air in the rear brake system from the get go. The dealers, including my service manager/head mech, said nothing was wrong. I bled mine and a lot of air came out. One member’s tech didn’t blow him off and flushed and bled the lines. You should flush and bleed yours. Its easy.
+1 with popgun on flushing.
What is the rotor color, compared to fronts?
What's an easy and effective method to flush & bleed? I've only done it on a car, the cumbersome way, with a helper pressing the brake pedal while I unscrew the bleed screw. Then I screw the bleed screw back in before the helper releases the brake pedal. Repeat until flushed and/or bled. A bit of a hassle.
I've seen mention of brake bleeders that people leave installed, a small fitting with a check valve in it. And I've heard of "power bleeders" that has some sort of vacuum.
Suggestions to make it easy are welcome!
I evacuate most of the reservoir, add fresh fluid, then bleed the "cumbersome" way.
It is so infrequent, I chose to not invest in specialty tools.
Definitely not criticizing those who do.
But I still recall all the specialty tools I gave away when I closed Cycle Tuning Unlimited in the eighties. Not to mention pounds and pounds of metric fasteners that I should have kept!
(07-18-2018, 10:47 AM)SportsterDoc_imp Wrote: I evacuate most of the reservoir, add fresh fluid, then bleed the "cumbersome" way.
Curious way to measure metric items. Tongue
Just sayin’.
Just sayin’.
Just sayin’.
Hmmm...how do you know I was not talking British monetary units?!
Your turn...
(07-18-2018, 08:54 AM)Lord Popgun_imp Wrote: At least 2 members (IIRC) had problems riding their rear brake. At least one overheated the rotor and warped it and, obvously, had to replace it.
When rotors or drums get very hot, such as from braking down a steep hill from a high speed, they are less likely to warp if the brakes are not applied after stopping, as the portion of the rotor or drum exposed to air cools faster than the portion to which the pads or shoes are applied.
Just sayin’.
Just sayin’. Good one! Rim shot!
This could get curiouser and curiouser!
  Rear brake pad replacement LongRanger_imp 39 3,707 05-03-2025, 10:45 AM
Last Post: Delphisa
  Rear Brake Pedal Adjustment Gone in 60 12 1,156 04-04-2024, 08:18 AM
   Rear brake pedal Mixagon_imp 28 2,211 08-06-2022, 07:29 PM
Last Post: Mixagon_imp
  Rear brake pad thickness. 17-CB-002 4 461 06-18-2022, 12:42 AM
Last Post: 17-CB-002
  rear brake question Crossfire_imp 12 905 02-18-2022, 03:02 AM
Last Post: bvictory_imp
  Rear brake rotor and new pads Sandhog_imp 13 1,015 01-08-2021, 04:51 AM
Last Post: ethan.phan613_imp
  Rear brake installation? White Dog_imp 9 852 07-27-2020, 02:48 AM
  Rear Brake "clunk" iogear99_imp 3 370 04-25-2020, 01:47 PM
  Rear Brake Help Needed White Dog_imp 21 1,622 10-01-2018, 07:10 AM
Last Post: Jim21680_imp
  Bike fell over, broke the front brake lever and bent the rear brake jlouis976_imp 24 1,774 09-14-2018, 12:35 AM
