Rear Brake "clunk"
Hi everyone. Long time lurker, first time poster. I have a standard 2014 CB1100 with 28k miles on the clock. I did a quick search on the forum, but didn't find anything similar.
For the past few weeks, I've noticed an intermittent "clunk" when I apply my rear brake at low speeds. After some trial and error I was able to isolate it to my rear caliper making contact with the swing arm. I was wondering if this behavior is normal?
[attachment=11095]
[attachment=11096]
I figure that this is what is going on. When I am stopped on an incline, and if I only engage my rear brake, my bike will slip backwards about a foot before it stops moving. Essentially, the rear caliper rotates counterclockwise, with the rear tire/disc, on the rear axle and it's movement is arrested by the brake lines Confused . When I get moving again and apply the rear brake , the caliper comes forward (clockwise) all at once until it makes contact (clunk) with the portion of the swing arm that juts out (indicated with the arrow).
If I'm looking at everything right, the caliper only has one hard point, around the axle, where it's fixed to the bike. So there's nothing to stop the caliper from rotating counter clockwise. It looks like this is putting a huge amount of stress on my rear brake line. Is anyone else experiencing this? I torqued my rear axle nut to spec 69 ft-lbs today but I'm still having this same issue.
Any input is appreciated.
Well that's easy, in the top picture of your post is the groove and in the lower pic is the square that fits in the groove so to speak and prevents the caliper from rotating in both directions of the wheel..
from what i understand your caliper just sits on top of the square, it should look like this;
And from the right side it should look like this;
Then the brake line should look like this;
Very well explained by the way and if you need to align the rear wheel this method may help;
https://www.youtube.com/watch?v=by7L3M8ai-0
Hope that clears that upWink
You're absolutely right. I didn't put the caliper back back in correctly when I replaced my rear sprocket. This makes total sense. Thank you!!!
Welcome iogear. Hello
  2014 DLX - rear ABS clunk kvdv_imp 11 910 12-14-2025, 10:29 AM
Last Post: Easynow
  Rear brake pad replacement LongRanger_imp 39 3,489 05-03-2025, 10:45 AM
Last Post: Delphisa
  18" Tubed Tyres UK Davidjill_imp 2 374 07-24-2024, 10:12 PM
  Front ABS Brake"Rain Stick" noise bflint 3 454 07-12-2024, 08:36 AM
Last Post: Race_ca1
  Delkevic 9" Oval Install Problems. jbird06_imp 4 457 06-11-2024, 08:25 AM
Last Post: devildogdoc_imp
  Rear Brake Pedal Adjustment Gone in 60 12 1,107 04-04-2024, 08:18 AM
   Rear brake pedal Mixagon_imp 28 2,135 08-06-2022, 07:29 PM
Last Post: Mixagon_imp
  Rear brake pad thickness. 17-CB-002 4 444 06-18-2022, 12:42 AM
Last Post: 17-CB-002
  2017 EX "Rim width Sizes" 17-CB-002 2 330 04-05-2022, 03:21 AM
  rear brake question Crossfire_imp 12 849 02-18-2022, 03:02 AM
Last Post: bvictory_imp
