Sometimes Ending Up Between Gears With Gear Indicator Line Blinking
Here's a method that works on just about any motorcycle for a clean positive shift: pre-load the shift lever. As you are going up thru the gears from a stop, place your toe under the shift lever and keep a little bit of pressure on the lever. When you reach your shift point, de-clutch and complete the shift motion. This eliminates that slight delay of moving your toe under the shift lever, then moving it up to contact the shift lever, then completing the shift.
I don't find the need for pre-loading quite so much on down-shifting. Sometimes I think about converting my bikes to a "race pattern" i.e. 1 UP for 1st, and DOWN for the rest.
I’ve never noticed my bike to ever miss an upshift. All down!
(05-15-2018, 11:33 AM)PowerDubs_imp Wrote: I’ve never noticed my bike to ever miss an upshift. All down!
becouse dogs are closer to engage on the next up-shift, and closer to "dog-to-dog" on the downshift (they need to engage on different flanks).
Once engagement starts, the tapper on the dog's flank will make full engagement as soon as there is any power driving the gears.
(It's easier when seen than explained here...) Rolleyes
You are the 2nd person to tell me that today-
I just received an email from the breeder that the parents are in heat and hopefully we should expect our new puppy around the end of July. Smile
I just received an email from the breeder that the parents are in heat and hopefully we should expect our new puppy around the end of July. Smile I like that "story"
Although this thread has gone to the dogs, I'll add my 2 cents:
Of the ~3 times I missed a shift, in >7,700 miles. I knew when I did it that it was a lazy shift and would not fault the Honda transmission.
(05-16-2018, 03:32 AM)SportsterDoc_imp Wrote: Although this thread has gone to the dogs, I'll add my 2 cents:
+1 Thumbs Up (37,000 miles for me)
(05-15-2018, 04:53 AM)3rdbike_imp Wrote: Here's a method that works on just about any motorcycle for a clean positive shift: pre-load the shift lever. As you are going up thru the gears from a stop, place your toe under the shift lever and keep a little bit of pressure on the lever. When you reach your shift point, de-clutch and complete the shift motion. This eliminates that slight delay of moving your toe under the shift lever, then moving it up to contact the shift lever, then completing the shift.
i hold this not for a good ideaa bcos in this moment you give already side pressure to this thin shift fork
https://www.google.com/search?q=switchin...6kTafD9FM:
+2
FWIW my 2013 didn't have a gear indicator, and I had no problem with missed shifts, but I did notice the gearbox got smoother after the 600 mile service, when I put in Honda full synthetic oil. didn't expect anything, but the improvement was noticeable.
  CB1100 on-line manuals Cormanus 5 1,207 04-06-2026, 10:45 PM
  Rear indicator (Turn signal) relocation bracket 2013 model AndyBeeMD 15 1,488 08-16-2025, 05:01 PM
Last Post: bflint
  Broken indicator lens spechg 6 649 04-18-2024, 03:01 AM
  Power source for oil indicator led norton1974_imp 1 262 12-31-2022, 10:07 AM
  Gear indicator Billie_imp 11 954 02-22-2022, 03:24 AM
Last Post: gswanson89_imp
  Service indicator - unleashed j3gq_imp 6 596 07-27-2021, 03:12 AM
  Do your gears "clunk" while downshifting? rjk555_imp 65 4,594 07-10-2021, 02:08 AM
  Fuel line retainer and dampener tod.branko_imp 16 1,224 07-04-2021, 04:28 AM
Last Post: tod.branko_imp
  Rear indicator design problem Mixagon_imp 5 493 06-19-2021, 04:23 AM
Last Post: Mixagon_imp
   Fuel line connection came undone and left me stranded! Riko_imp 33 3,508 12-04-2020, 12:29 PM
Last Post: 17-CB-002
