Engine using oil - problem ?
My CB used oil one trip and I had to top it up. It’s never happened again.
Hi everyone , I have oil consumption on my ex model as well , after last oil change at my dealer I drove like 600 miles and there is no present of oil in check window . Also I got oil leak spots at front of my engine , not sure how you call it , rubbers probably would be the case . My bike is still on warranty but I assume my dealer will say oil consumption is totally okay with after market exhaust .(
I had a new R9T for a while, it didnt use a drop for the first 700 or so miles but as soon as i started to rev it out a bit more (post running in period) It used about a litre over the next few hundred miles. As soon as i noticed it i kept a close eye on the sight glass so that it didnt run too low. I figured it was just bedding itself in. 10/30 oil does seem really thin to me so i'm gonna use a good quality semi synth 10/40 in mine.
(06-13-2018, 04:31 AM)PowerDubs_imp Wrote: Oil in the sight glass can change quite a bit depending on the angle of the bike and how long it has sat before checking.
If you are really burning that much oil - I would think it would be visible by sight- blue when throttled.
Instead of using cardboard as a funnel- why not rig a piece of cardboard flap at the muffler output. If you are burning oil it will show (if the end of the pipe itself is not already..)
Curious to hear an end of the story- if burning, is it rings, valves, valve seals, ....
+1...if burning oil, usually valve seals could be the prime suspect, as the is the hottest spot of an engine, assuming there is no defect with other parts
  CB1100 Idle speed instability problem ericlo69_imp 1,434 116,782 07-26-2026, 01:51 AM
  idle problem update 1973cb750 37 2,013 05-12-2026, 08:38 PM
Last Post: rdprdp01
  Chain or sprocket problem ? The Gecko_imp 14 1,197 07-30-2024, 10:05 AM
  O ring chain problem Mixagon_imp 7 630 10-17-2023, 07:28 AM
  About the problem of high idling. (2014 cb1100ex) DDUMZI_imp 62 4,542 08-02-2023, 05:38 PM
Last Post: DDUMZI_imp
  May have a problem the Ferret 12 838 01-20-2023, 04:53 PM
Last Post: max
   2017 EX Headlight Dimmer Switch problem? sleeper_imp 24 1,791 10-08-2022, 12:27 PM
  Fast Idle Problem Solved Nachodaddy 17 1,435 10-08-2022, 09:18 AM
  Another High Idle Problem emptysea 60 3,837 07-05-2022, 11:41 AM
  Tail light install problem iamheero_imp 9 681 11-27-2021, 02:58 AM
Last Post: Bazbro_imp
