Engine using oil - problem ?
CB1100 DX is using excessive oil I think. At OD reading 22.5K miles (last week), had dealer change oil and filter before I started touring. Toured for 6 days and 2500 miles (OD reading 25k) and check oil. Nothing registered in the oil window. Totally surprised me. Added quart and registered between low/high lines in window. On day 7 dropped in at Honda dealer and had them change oil and filter again; they filled to above high line in window. I road another 200 miles today and level registers half way between low/high lines in window. I think I have a problem but want to continue my tour (in Michigan now .. home is San Diego). FYI, first 1200 miles of tour my MPH was 85-95, 100 sometimes. Next 1200 miles was 80-90 MPH. Last few hundred miles at 75-80 MPH (since getting last oil change). First thought is just to keep adding oil and keep touring. ANY THOUGHTS?
Wow first I've hear of any CB 1100 using oil. You do seem to be running it kind of hard IMO, but not sure that would have much bearing on the oil loss. I would keep touring and just check it nightly. Use a V shaped strip of torn /folded cardboard for a funnel and carry a bottle of Honda oil with you.
Strangely just changed my oil on 2014. It drained about 3.75qts. Added 4 qts and line is above the high mark now. Weird. Thought it held 4.1 qts?
For my oil level checks, I use the start and idle 3 to 5 minutes from cold, then let it sit 3 to 4 minutes before checking the oil level, as outlined in the manual. I am guessing that the oil capacity spec. in the manual is for a completely empty engine and new oil filter. It seems that there is always a little oil that does not drain from the sump, and a little more trapped on the old filter, during an oil and filter change, which may or may not be part of the difference Memphismike mentioned.
I agree with 2017ex. The 4.1 includes oil in the filter and you're never going to drain every drop. That being said I did my first (600 mile) change a couple of weeks ago and after I had added 4 quarts and let it run a bit the oil settled right in the middle of the two lines so I topped it off a bit to bring it close to that top line.
Oil in the sight glass can change quite a bit depending on the angle of the bike and how long it has sat before checking.
If you are really burning that much oil - I would think it would be visible by sight- blue when throttled.
Instead of using cardboard as a funnel- why not rig a piece of cardboard flap at the muffler output. If you are burning oil it will show (if the end of the pipe itself is not already..)
Curious to hear an end of the story- if burning, is it rings, valves, valve seals, ....
Thanks for all replies. Have had no oil/engine lights and engine still purrs so will just carry some extra 10-40w while on the trip.
Which brand of oil are you using and perhaps 10/40 would be better for your riding style than a 10/30.
I assume that it does not leak oil , check the plugs to see if it burns the oil.
It can NOT disappear into the cooling system !
Never asked what weight the Honda dealer services department put in. Oil level seems to be holding ok now.
My 2005 ST1300 used a quart of oil once on a trip to NC. I topped the oil off in Franklin and continued the trip. Never had any oil usage problems after that incident, strange.
  CB1100 Idle speed instability problem ericlo69_imp 1,434 116,770 07-26-2026, 01:51 AM
  idle problem update 1973cb750 37 2,013 05-12-2026, 08:38 PM
Last Post: rdprdp01
  Chain or sprocket problem ? The Gecko_imp 14 1,197 07-30-2024, 10:05 AM
  O ring chain problem Mixagon_imp 7 628 10-17-2023, 07:28 AM
  About the problem of high idling. (2014 cb1100ex) DDUMZI_imp 62 4,541 08-02-2023, 05:38 PM
Last Post: DDUMZI_imp
  May have a problem the Ferret 12 838 01-20-2023, 04:53 PM
Last Post: max
   2017 EX Headlight Dimmer Switch problem? sleeper_imp 24 1,791 10-08-2022, 12:27 PM
  Fast Idle Problem Solved Nachodaddy 17 1,435 10-08-2022, 09:18 AM
  Another High Idle Problem emptysea 60 3,837 07-05-2022, 11:41 AM
  Tail light install problem iamheero_imp 9 681 11-27-2021, 02:58 AM
Last Post: Bazbro_imp
