Break pads.....just in time....so eaaaaaasy!!!!!!
I'm on my third set of pads, 1st set lasted 19,102. Second set lasted 17,807 but they would have gone more, I needed new tires so just replaced the pads while I was in there. I use both brakes equally so replace them in pairs like the tires.
If you spend most of your time riding where there are stop signs and stop lights you will use up your brake pads a lot quicker than if you ride out in the country with few stops, or ride across the country on the expressway where you only use your brakes a couple times a day. I have ridden hundreds of miles without ever touching the brakes, and have ridden where you are stopping every few hundred yards it seems. One is harder on the brakes than the other.
(04-11-2018, 12:11 AM)pdedse_imp Wrote: jdvalero, not to sound condescending or anything like that, but could it be your foot is resting on the brake pedal causing your rear brake to wear out substantially sooner than what others experience? I ask because several members have commented on the tight spacing down there and the way the foot peg is set, it's easy for the left edge of the front of the boot to depress the pedal without the rider realizing it. When I first got my CB, I had just read of that on the forums here and more than once when I looked down I noticed that my boot was indeed half on the brake pedal and I didn't even know it.
Not condescending at all...good question. Answer is no. I have the (bad or good) habit of getting my right toes on the peg the soonest I start to move.
Sent from my SM-G955U using Tapatalk
(04-11-2018, 01:27 AM)The ferret_imp Wrote: If you spend most of your time riding where there are stop signs and stop lights you will use up your brake pads a lot quicker than if you ride out in the country with few stops, or ride across the country on the expressway where you only use your brakes a couple times a day. I have ridden hundreds of miles without ever touching the brakes, and have ridden where you are stopping every few hundred yards it seems. One is harder on the brakes than the other.
That must be it. I'm mostly in downtown traffic...but I still feel cheated out on 10k breaking distance. Dang it!
Living in a rural setting is the difference on brake wear. My commute to work before retirement was 30 miles one way and included 4 stop signs and zero traffic lights. Going on 16,000 miles on my CB and the pads still look good. My Nissan PU went 97,000 miles on the front pads when I changed them and the OE's still had some life left. The rears have 115,000 and are original. When I lived in the city I felt lucky to get 20,000 on a set.
Sorry if im hijacking your thread. I had a look at my front calipers on my RS and i realise there are no retaining pins holding the pads in place. Does anyone have experience in calipers that are designed this way? Looks like the pads are held in place by a clip instead.
I just replaced my rear break pads for the first time. I’ve never really inspected that area before and upon hooking everything back up the whole mounting break component that houses the pads and caliper seems to move ever so slightly when I apply the break. Is it normal for this to move? I figured it was since there are rubber buffers between the two mounting bolts. Any info would be awesome.
My sold 2013 ABS, passed 53000 km and still good for 5-8 K, if I continued riding it.
Conditions: mostly long distance/hwy ridden, gear down to much speed, final meter (3.3 feet), I use rear mostly for smooth stop.
(04-09-2018, 12:23 PM)jdvalero_imp Wrote: I give it half a mustach on the 1-5 difficulty Beard scale.
You only need a 12mm and a 8mm socket or wrench.
Jdvalero,
...half of moustache of length or thickness on the 1-5 difficulty Beard scale ???. Smile
  Brake Pads... Simplified Yata-Garasu_imp 20 1,933 03-02-2025, 08:28 PM
  What did I break? Cbcarolina_imp 4 430 12-03-2023, 10:44 PM
  Any one use Ceramic Brake pads? mvk24_imp 6 689 05-14-2022, 12:53 AM
Last Post: bvictory_imp
  brake pads which is best? modmaster_imp 32 2,405 08-27-2021, 10:21 AM
Last Post: jimgl3_imp
  Suggested brake pads? mvk24_imp 12 1,028 03-21-2021, 04:05 AM
  Rear brake rotor and new pads Sandhog_imp 13 1,020 01-08-2021, 04:51 AM
Last Post: ethan.phan613_imp
  Correct part number for front brake pads Frulk_imp 7 655 02-18-2020, 08:06 AM
Last Post: iamheero_imp
  Replaced front brake pads for 1st time at 20K miles Frulk_imp 15 1,077 01-04-2020, 02:15 AM
Last Post: Bheezy27403_imp
  How to change front brake pads 2013 abs ? 562loosenoodle_imp 20 1,269 02-04-2019, 01:47 PM
  Engine break out tips and tricks ACE_IRA_imp 7 530 01-29-2019, 12:30 PM
