Fueling without cam sensors
Fueling without cam sensors can also be achieved with engines without camshafts, or cam-less engines.
Pretty advanced technology, but should not really be a surprise in the year of our time 2019.
(10-02-2019, 02:29 PM)m in sc_imp Wrote: its not that hard to program. the cam is a direct relation to the crank. The code will just count the pulses and interpolate the position. its not a single pulse. fyi, theres NO map sensor on the grom. you can do it simply with the crank signal, engine temp, some sort of an 02 (unless you are running a static map), and tps.
Yes, you're right, no MAP on the Grom. But again, how can crank signal know which of the two revolutions of the crank in relation to the cams?
Crank and cam are not a direct 1:1 relation, as it takes two revolutions of a crank to turn the camshaft once. On each revolution of the crank, the crank pulse sensor reads the exact same signal. Yes, the ECM can be programmed to fire and fuel on alternate crank revolutions, but how does it establish which of the two revolutions?
If it is all in the ECM, then if the ECM is unplugged, the crank turned once, the ECM plugged back in, the engine will always start normally.
That suggests that all bikes would not need cam position sensor, yet some do.
LakeWylieJoe I like this puzzle and enjoy all the answers we get, you are right, how does the bike decide if it starts with the left foot or the right footHuh
It has never been a problem with carbs and the waisted spark, i got that but this is a new trick, i have three options and they are all different, in the mean time i have deleted the last one, our bike does not fire the injectors at the same time for cylinders 1 and 4 ( like the spark ) at half the dose when it is running but it has worked out which piston is on the intake stroke and doses each injector accordingly every time it starts.
but how? maybe the ecu has electronic dice?ROFL
Never given it a thought but it keeps me thinking and enjoy some more answers, which is a good thingCelebrate
Not suggesting the immediate demise of the [woefully antiquated] internal combustion engine, but the discussion of cam synchronization, maximum efficiency tweaks and so on - I wonder if analog discussions were going on during the final years of the stream-driven locomotive? We are likely living the era of the best known methods to squeeze every joule of energy out of every drop of dino. This could go on for awhile, but sadly it will eventually be dust in the wind and displays in museums and retro restaurants.
(10-02-2019, 04:13 PM)GoldOxide_imp Wrote: Not suggesting the immediate demise of the [woefully antiquated] internal combustion engine, but the discussion of cam synchronization, maximum efficiency tweaks and so on - I wonder if analog discussions were going on during the final years of the stream-driven locomotive? We are likely living the era of the best known methods to squeeze every joule of energy out of every drop of dino. This could go on for awhile, but sadly it will eventually be dust in the wind and displays in museums and retro restaurants.
We will be the dust in the wind, and school kids will be tele-ported to the i-phone museum, to see what communications was like before microchips were embedded in their brains......
ROFL Yeah, I somehow don't doubt.
hmmm... interesting... could it be the computer always tried twice, only during engine start, to know if its power stroke or intake stoke? The mark gear will already tell us which pair of cylinder is at the bottom and which at top. when we crank, computer will inject into a pre-pick cylinder at bottom. if its alive (means its the correct cylinder), continue with the sequence. if no go, will inject again when that same cylinder go bottom again. This way, maximum only 1 injection is lost during startup. guess once and go if correct, reset sequence if wrong. But maybe Honda engineer have a more canny way...
Stuck in jam for an hour driving, i think of another way to do it. . Just do it like those single cylinder engine. By trying to light up only 1 cylinder. Once u got 1 right, the sequence for the rest are known.
pekingduck is making the correct point (in a lot fewer words than I did).
Also, I'm certain the system is not programmed to inject fuel into a closed port--even a carburetor works smarter than that.
Whatever Honda figured out, it's very clever. I'd love to get to the bottom of this. The mechanics at the local Honda shop are also scratching their heads after I mentioned the issue yesterday while buying some oil. Maybe I can get one of them to make a call to a corporate tech guy.
For the sake of being complete, here's what got me thinking about the issue.
When the cams come out, you have to pull at least one of the cam sprockets off as there is not enough slack in the cam chain, even with the tensioner backed all the way out, to remove the cams with the sprockets on. To get a sprocket off, you have to pull one of the two sprocket bolts out (you start with the cam timing marks at #1 TDC on the compression stroke to access the first bolt) then turn the crank by hand one full cycle to expose the second bolt on the opposite half of the sprocket. You are now at #1 TDC exhaust stroke. Once both sprocket bolts are off, you can work the sprocket loose to one side and pull the cam all the way out through the sprocket hole.
Handy tip for first-timers: You only need to remove the sprocket from the intake cam--there is plenty of slack in the chain to get the exhaust cam out with its sprocket still on once the intake cam is out. The intake one has to come off because it's on the slack side of the chain.
The first two times I adjusted valve clearances, I dutifully turned the crank over one full cycle with the cams out (back to what was #1 TDC compression stroke) before reinstalling them with their timing marks in the correct position. You then have to turn the crank one more cycle to get the second sprocket bolt back in.
This time, I got to thinking the ECM can't be counting crank cycles to figure the cam timing--the battery isn't even hooked up! I put the cams in 180 degrees out of phase from how they came out (due to the one full crank turn to get the second sprocket bolt out). I figured as long as #1 was TDC on the crank and the timing marks on the cams were correct, it should work. Sure enough, it fired right up once reassembled.
Again, how the does the ECM determine cam position solely from the CKP? For every turn of the crank, the cams only turn 1/2 cycle. In other words, for every possible crank position, there are two possible cam positions, and the fuel injector timing depends on the cam position.
For the benefit of mr Norris et all ( not mr K ) here is a video clip that shows in slow motion what the injectors are doing when the engine fires up from cold.
Two led's are connected across injectors 1 and 4, they light up when the injectors are operated, there is one double firing at the start button push and then another four double shots of fuel into both ports.
After what seems like a small pause the no1 cylinder fires and then no4 cylinder and so on.
It appears that the double dose just gets the ( cold ) engine going and the decision ( electronic dice ) is then made by firing one cylinder at a time and waiting for the crank sensor to report a higher frequency at which time success is registered and the engine runs in the " uneven " sequence.
There is a lot more to this of course but now we know a bit more about what actually happens.
You all may have noticed that it takes the cb1100 to always take a bit of time to start up even if it is warm, the next question is; what if the engine is bump started, does it remember in what sequence it was before it stopped?
The clip is slowed down to 7% speed but the pitch of the sound remains the same hence the eery soundtrack, the unusual firing of the led's once the engine is running is the result of the frame rate and rev's mismatch and appears out of sync, in reality they fire at the correct time and sequence, i had a hard time getting this part as best i could on video;
https://youtu.be/9yPijlJBang
And Joe, would you be able to tell us what the clearances and shim sizes were before and after so we can complete this thread here;
http://cb1100forum.com/forum/showthread....#pid139671
  Wheel sensors The Gecko_imp 48 3,780 07-27-2023, 03:51 AM
Last Post: The Gecko_imp
  CB1100 EX fueling & speedo Ol' RedJ_imp 7 601 07-16-2023, 02:17 AM
  O2 sensors on 2014 DLX Houtman_imp 15 1,014 12-18-2020, 10:02 PM
  Fueling and Air overhaul imminent. looking for any advice misterprofessionality 111 7,728 05-08-2019, 12:14 PM
  High revs after re-fueling. Tezza_imp 12 1,169 08-07-2015, 03:29 PM
