Unhealthy Engine Knock / Noise
I'm no expert, and I note the experience of others, but I find it very hard to believe a noise like that would be brought about by the weight of oil in the engine.
Another golden opportunity to be wrong, I guess.
I hope you solve the problem spakins
After 2 oil changes I would think another would make no difference.
Sent from my iPad using Tapatalk Pro
New tech, new dealer, get a hold of Honda. I would not accept this issue from Honda
(05-10-2017, 10:11 AM)Dave_imp Wrote: My bike sounds just like this when I first start it up every time, but maybe not as loud. The sounds gets much quieter after about 30 - 60 seconds of running. Does your bike do this all the time, even after warming up? Hope you figure it out.
I went back and listened to the video again, and I was mistaken. The sound my bike makes is similar, but not identical. Also, my bike sometimes (not always) makes a similar sound on start-up, that quickly goes away. I read on another post, on this forum somewhere, that the fuel injectors make a clicking noise, and I think that is what is causing the noise on my bike. I listened closely next to the fuel injectors one time and it did sound like the sound could have been coming from that area. The sound on your bike does seem to be coming from the RH side, front of the crankcase, but maybe you can try listening closely to the fuel injectors and try to determine if the sound is coming from there? Just trying to help to eliminate as many possibilities as possible. Good luck.
See the thread under general discussions titled "Getting ready for riding season greeted by bad sounds...
You may want to adjust the balancer backlash. It's on page 11-13 of the '13 service manual. It's very easy to do.
Your video at 40 seconds is focused on the backlash adjustment.
Loosen the pinch bolt and then take a screwdriver and turn the shaft counter clockwise until the engine makes a whining sound (gears are too tight/backlash is too small). Then turn clockwise until the noise stops. If you continue to turn the shaft too far clockwise the engine will make a rattling noise (gears too loose/backlash is too excessive).
Thanks again for all the ideas and replies. The only other thing different I did (besides oil viscosity) is use a K&N oil filter. The tech said that there was red debris of some kind in my oil pay. He said it looked like liquid gasket or the like.
I may try, or ask the tech, to blow out my oil passages with compressed air to see if there is an intermittent block of some kind. From what I can see in the K&N filter (I saved it) there was no red material of any kind.
you might want to use the search engine on K&N oil filters. Quite a few of them have been tearing at the nut, and leaving members with a huge mess on the road. (Edit not to say this is causing your problem..just trying to prevent ANOTHER problem lol)
Strange that this didn't happen until right after an oil change. Also, the K&N filter incident we saw on here is pretty unnerving.
By all means I'm a nobody when it comes to diagnosing engine noises but the sounds I heard in the video sounds exactly like the problem I had with my TW200 that turned out to be an issue with the valves.
I'm with Curly on this. The noise is loudest when the camera is right at the balancer adjustment. Its easy to adjust and worth a try. Curly posted the procedure, which is just what the manual says.
IIRC, when the bikes first came out in '13, a UK member on the UK board had a balancer problem. The only one reported that I know of.
spakins, beware the K&N filter. See http://cb1100forum.com/forum/showthread.php?tid=9576
Spakins, you most likely have a bad cam chain tensioner and and it's easy to replace yourself in a few minutes for under 60 bucks. It's ref# 3 and a new gasket is ref # 7 in the following link:
http://www.hondapartshouse.com/oemparts/...-tensioner
It doesn't surprise me that the dealer tech didn't suggest changing it, while saying he couldn't find anything wrong. Also, I don't recommend blowing compressed air through the oil passages as you mention above.
  Front wheel bearing noise? MagnaRider 20 1,905 03-31-2026, 08:20 AM
  Engine clicking/ticking metallic noise! WTF? Tortuga_imp 28 2,368 10-11-2024, 04:53 AM
  2014 rear wheel knocking noise dunebuggy_imp 7 976 08-05-2024, 03:33 AM
Last Post: Yata-Garasu_imp
  Front ABS Brake"Rain Stick" noise bflint 3 475 07-12-2024, 08:36 AM
Last Post: Race_ca1
  Fuel pump noise? Ben70_imp 15 1,025 07-16-2022, 12:22 AM
  Valve noise (i think) Maturecheese_imp 6 656 07-08-2022, 03:41 AM
Last Post: 1973cb750
  Brake disc rubbing noise mrded_imp 8 736 08-17-2021, 03:20 AM
Last Post: furious_blue_imp
   Ticking noise from top part of engine Kingkong_imp 40 2,904 03-18-2021, 01:22 AM
  Strange wizzing noise LoyalKhan664_imp 28 2,207 10-02-2020, 05:58 AM
  Lower engine knock airenping_imp 33 2,448 09-20-2020, 12:19 PM
