strange start
Maybe a temporary fuel "air lock" situation brought on by low pressure and dampness? I have never experienced it on a CB1100 and we get all four seasons of nasty. Never used the throttle on cold start-up either.
If my CB1100 has been sitting more than a week without starting I crank the engine with the throttle wide open for a few seconds. My understanding is that this prevents the fuel pump from pumping in order to unload the cylinders in case the engine is flooded. The engine won't start with the throttle wide open.
My theory is that by cranking the engine without starting it the oil pump pumps some oil to lubricate the pistons and valves. Releasing the throttle and cranking the engine starts it right up. My hope is that by doing this I am reducing wear on startup by insuring the engine parts have a nice coat of oil when starting after having been sitting for a long time. Maybe this is a pipe dream. Hopefully it causes no harm.
You probably worry too much about wear on the engine parts.
Yeah, most 21st century engines, in particular performance-like engines, have the engineering of lubrication all ironed out supposedly under all riding/driving conditions. My experience has been for the CB1100 that it starts and behaves the same whether the environment temperature is -25C or +45C. I just press the starter and let the engine controller do the rest. I could not say that for any of my '70 or '80s bikes where I had to fandango air/fuel supply, especially near freezing temperatures and lower.
There is no more "rocket science" in these routine engines. There are, however, cost cutting and performances enhancing tweaks. Example: Many new cars use ceramic cylinder "liners" now in which it is a spray-on application. In this case, there is no steel liner.
(11-30-2018, 09:56 PM)Houtman_imp Wrote: You probably worry too much about wear on the engine parts.
Probably true, although I always heard the majority of engine wear occurs at startup. The Castrol Actevo motorcycle oil I use makes a big deal about saying how it contains "Active Protection Molecules cling to the surfaces of your engine giving an active and continuous layer of protection as well as an ultimate shield against cold starts." Reducing wear on Cold starts seems to be important to them.
Using advance lubricant seems to be a rider/driver (in the case of cars) consensus. Keep in mind manufacturers like Honda engineering worry about start-up starvation from a design point-of-view and without any consideration for special lubricants. They have to ensure the design meets their specification with standard oils first. So as long as you maintain the machine as recommended by Honda (in this case), you should be fine. If you ride hard, consider the extra insurance suggested advance lubricants can provide.
Make the long story short: I do not care about any special (if) molecules in automotive oil..as claimed..
I always use recommended, as per manual (viscosity may change due to different climate) oil, cars/bike.
In Canada, as severe climate country, I use 100% synthetic for: both cars in winter only, and CB year round/due to extended long distance rides (hot). Synthetic provides better engine protection across the board.
Synthetic oil has immediate flow even in clod temperature...but how cold is your bike when you first started, 0*C/32F, or warmer???
The bottom line: don't go below manufacture recommendations, and you'll be fine for sure....worry less, ride more Smile
AMEN
I used to use synthetic almost religiously in vehicles, but the winter climate and road salt took heavy toll on all other aspects other than the engine. Those vehicles were typically traded away. So I stopped a long time ago and my engines haven't appeared to suffer noticeably more (e.g. not burning oil, no fast oil contamination, etc.). I still believe synthetic is useful, especially in the north (for our American members I suppose that means "far north"). I am still on the fence regarding clutch performance gain since I don't drag the CB, but I have used synth on the CB.
I have started and operated the CB many times at -10C and lower on GN4 oil. Always prepared for some unruly monster sounds that do not appear each time. The beast comes nicely alive each time (87 octane fuel too). To be honest, I never expected the CB to be this consistent.
Why, when Honda recommends GN4 and 87 octane fuel, would you worry about using it?
Precisely.
  High engine revs on start up CBX1000_imp 21 1,740 06-06-2024, 02:40 AM
  CEL after Jump Start rage91_imp 23 1,504 04-14-2023, 01:25 AM
  Won't start RLS_imp 5 435 05-12-2022, 05:58 AM
Last Post: RLS_imp
  CB 1100 won't start GeorgiaRider_imp 30 1,961 12-19-2020, 11:19 PM
  Low rattle on cold start. shahyaan_imp 22 1,486 11-30-2020, 12:01 AM
  Strange wizzing noise LoyalKhan664_imp 28 1,958 10-02-2020, 05:58 AM
  Bike crank but wouldn't start. zirconxi_imp 67 3,828 04-25-2020, 01:37 AM
Last Post: White Dog_imp
  Won’t start? bsavoy04_imp 26 1,419 08-05-2019, 04:38 AM
Last Post: LongRanger_imp
  2014 Start - Cutoff Switch Question deltamark 16 1,245 04-18-2019, 06:23 PM
Last Post: flynrider
  Motorcycle doesn't start, high oil temperature indicator comes on Saarang_imp 17 1,153 07-20-2018, 07:14 AM
Last Post: SportsterDoc
