06-09-2020, 06:17 AM
Thanks, Peter. I take it picture 2 is the standard bolt 90127-MCJ-750?
Rear Bungee Hook
06-09-2020, 07:46 AM
All these are OEM, were removed due to SW Motech side racks installation.
06-09-2020, 08:01 AM
That's great information, Peter, thanks. It tells me the thread length of the OEM bolt is 42 mm which probably means the ones PekingDuck has told me about are 55mm thread length. I just have to work out whether they're long enough and, if they are, see whether a Honda dealer can get them for me.
06-09-2020, 09:11 AM
(06-09-2020, 08:01 AM)Cormanus_imp Wrote: That's great information, Peter, thanks. It tells me the thread length of the OEM bolt is 42 mm which probably means the ones PekingDuck has told me about are 55mm thread length. I just have to work out whether they're long enough and, if they are, see whether a Honda dealer can get them for me. OK, no problem, the bolt is M8x1.25 mm Let me know if you need further assistance in this matter.
06-09-2020, 10:18 AM
Do you really need the hook? If you have a rear rack can’t you tie down anything to the rack itself? My rack has some hook points for a cargo net or other lashing.
06-09-2020, 10:21 AM
06-09-2020, 11:07 AM
chync, no I don't REALLY need it, but it would look good and be handy.
pekingduck, thanks. The thread is the same diameter?
06-09-2020, 11:11 AM
The reason I had those bolts was because I had a Nelson-Rigg Seat bag that I had modified to fit securely on my 2013 and 2014 bikes. Originally, the bag's straps were sewn into the outer edges of the bottom, and had plastic clips.
I cut the straps and bolted them to the bag's base, and used metal clips that fully encircle the bolt. I cut eyelets in the loose ends of the strap that went onto the bolts first so the metal buckle didn't rub the chrome grabrail. On the 2017, the front bolt was too far forward, on the upper shock mount, and had only a 6mm thread. So I replaced it with a bolt, and ordered 2 of the 42mm 2013/2014 bolts. I used some chrome spacers that were about 15mm thick so the hook ends would stick out from under the seat. But the 42mm bolts were still too long - they went into blind holes, so I had to shorten them around 12mm. (06-09-2020, 11:07 AM)Cormanus_imp Wrote: chync, no I don't REALLY need it, but it would look good and be handy.Yes, 8x1.25 as Peter noted.
06-09-2020, 01:29 PM
Turns out the bolts I've had the rack attached with are 60mm long. They go through the rack and then a spacer and then the garnish. I suspect taking the the garnish off would make little difference as the rack will still have to be spaced out about the same distance from the frame. So, I'll keep looking.
I have discovered that Honda used the 42mm bolt, 90127-MCJ-750, on the CBR954 Fireblade's muffler. It also had a 47mm version of the same sort of bolt (90116-MAT-000) which is also used on the CB1300. These things are easy to find if you have the part number; not so easy without. Edit: I may have found a 60mm version for the muffler of the CB1000—P/N 90117-KGB-610.
06-09-2020, 10:41 PM
Bolt Depot is a good source for fasteners.
« Next Oldest | Next Newest »
| New Rear Tire and Rear Brake Pads | memphismike_imp | 5 | 524 |
06-11-2018, 09:35 PM Last Post: memphismike_imp |
| battery tender cable hook up | ss2wheels_imp | 7 | 440 |
07-10-2014, 03:12 AM Last Post: Gumby 1100_imp |
