09-25-2020, 01:16 PM
You are not alone, Sēnor Ferret. I remembered it because I had cause to look it up recently.
age date on tires
09-26-2020, 09:38 AM
Gosh... I still have the original tires on my 2014... and 7000 miles. I need to ride more... I know. Next year!!!!!!
09-26-2020, 12:14 PM
(09-26-2020, 09:38 AM)ride4now_imp Wrote: Gosh... I still have the original tires on my 2014... and 7000 miles. I need to ride more... I know. Next year!!!!!! Should be fine as long as there are no cracks in the tread wells and/or side walls. If the tire is going kinda funky, maybe like hard and waxy, maybe reassess its grip performance too.
09-26-2020, 12:42 PM
(09-25-2020, 12:59 AM)rickcb_imp Wrote: The date code of my PR3 front tire that showed the cracking is 1314 so it was made in early 2014. I had the tire installed less than two years ago. I bought the tire from RevZilla. I'm surprised they had such old stock. I knew it. Thats the trouble with those pr3 tires nowadays. Youre buying old stock. Did you ever swap those shoes?
09-27-2020, 04:32 AM
(09-26-2020, 12:42 PM)misterprofessionality_imp Wrote:(09-25-2020, 12:59 AM)rickcb_imp Wrote: The date code of my PR3 front tire that showed the cracking is 1314 so it was made in early 2014. I had the tire installed less than two years ago. I bought the tire from RevZilla. I'm surprised they had such old stock. I knew it. Thats the trouble with those pr3 tires nowadays. Youre buying old stock. Did you ever swap those shoes? I put another 250 miles on the bad one today. I'm waiting for the Angel GT back tire to be available. It was out of stock everywhere.
09-27-2020, 06:21 AM
This is the reason that I buy my tires from a local dealer , you can check the date and refuse them when you think that they are too old , keeping in mind how many miles you will ride on that tire in a year.
09-30-2020, 12:17 PM
In the UAE the law states that tires cannot be older than two years in order to pass the annual technical testing, so looking at the mfg date codes is something we do. Normally one could pass the test even if the tire is in its 3rd year, however it must be a fairly unused tire, otherwise - fail.
I just picked up a pair of Avon Roadriders to mount on my new CB1100, they are 2619 from the local Avon dealer, so should be fine for the next two registrations, they were also quite inexpensive, only just above 200$ for the pair. I have had very good experience with Avon in the past having used Cobra Chrome tires on my MG California, so I thought "why not?" Sent from my ONEPLUS A5010 using Tapatalk
09-30-2020, 12:27 PM
Yikes! Tires not older than two years? $200 for a pair of tires would have to be reasonable. The region must recycle (??) a lot of vehicle tires.
09-30-2020, 01:23 PM
(09-30-2020, 12:17 PM)tod.branko_imp Wrote: In the UAE the law states that tires cannot be older than two years in order to pass the annual technical testing, so looking at the mfg date codes is something we do. Normally one could pass the test even if the tire is in its 3rd year, however it must be a fairly unused tire, otherwise - fail. I guess that would encourage people to ride their bikes more.
09-30-2020, 01:29 PM
(09-30-2020, 12:27 PM)GoldOxide_imp Wrote: Yikes! Tires not older than two years? $200 for a pair of tires would have to be reasonable. The region must recycle (??) a lot of vehicle tires.Intersting observation, and yes, you are correct, tires are recycled quite a lot for asphalt manufacturing, but I also suspect a lot if older, fairly unused tires find their way to South Asia and West Africa where they are sold "as good as new" Sent from my ONEPLUS A5010 using Tapatalk |
« Next Oldest | Next Newest »
| Yuasa battery date code | max | 10 | 837 |
04-13-2020, 06:06 AM Last Post: Cormanus |
| New Tires - Manufactured Date - What is Fair and Reasonable | Marc_imp | 32 | 2,203 |
02-21-2018, 01:32 PM Last Post: jimgl3_imp |
| Tire Date ? | JF Coastal_imp | 17 | 1,358 |
12-21-2017, 05:47 AM Last Post: Cbgaz_imp |
