Tire Date ?
Hey Guys,
Checking my tires for the date manufactured just now. And inside the tire in the oval it reads 6215. My bike is a 2014 and the last time I checked there is only 52 weeks in a year. Any thoughts ? They are the OEM tires by the way.
THanks,
JF
(12-19-2017, 04:32 AM)JF Coastal_imp Wrote: Hey Guys,
THanks,
JF
What brand of tire, Dunlop or Bridgestone? Better double check that date code.
There is nothing to be concerned about, the tire was made in 2015, unless you are noticing some cracking or other physical defects.
If you were doing a track day with a fast super sport bike, no I wouldn't run any tire that old, but for the CB1100 as most riders use it, there will be no compromise to grip or handling at all. Manufacturers say five years shelf life is standard, you are well within that.
[url=https://www.dailymotion.com/video/x3tiit5]Motorcyclist-Ari Henning on Tire Life and Service
I never worry about getting old tires, I wear them out in 6 months lol
THanks,
JF
That’s strange because my tyre is also 6215. On a Dunlop. Mines a 2013 model don’t think it’s OE. I have asked around and nobody’s got the answer.
If you look 180 degrees from the 6215, you will find the date code, preceded by DOT EUIX on mine.
In the oval: WANM 0814 = 8th week of 2014
For my Dunlops, the EU after DOT indicates plant location
Sumitomo Rubber Industries
City of Toyota
Aichi Prefecture
Japan
http://www.harriger.com/tire5.htm
Just in case you wanted to know (probably not!)
(12-19-2017, 10:30 AM)SportsterDoc_imp Wrote: If you look 180 degrees from the 6215, you will find the date code, preceded by DOT EUIX on mine.
Yep, there are several codes stamped about the tire, must ensure you are looking at the right one.
6215 is in the oval.
so 62nd week of 2015 then lol
As it is on mine, however it is NOT preceded by DOT and is not the DOT code.
  age date on tires the Ferret 19 1,382 09-30-2020, 01:29 PM
Last Post: tod.branko_imp
  Yuasa battery date code max 10 744 04-13-2020, 06:06 AM
  Tire replacement - Not a "Tire Thread" SportsterDoc 12 941 07-18-2018, 06:50 AM
Last Post: SportsterDoc
  New Tires - Manufactured Date - What is Fair and Reasonable Marc_imp 32 2,032 02-21-2018, 01:32 PM
Last Post: jimgl3_imp
