Strange wizzing noise
So I tried to replicate it today on the stand but no success. It only does it when accelerating under load which leads me to think it might be a bearing. I’ll take it to the shop. Thanks for the advice guys!
I think one member had a loose driving sprocket's bolt behind L/side cover ??
If so, it may not sound like a bearing, as you suggested, but it may be more noisy under a real load, when ridden, not on the center stand when being span without a load....
(09-25-2020, 07:26 AM)peterbaron_imp Wrote: I think one member had a loose driving sprocket's bolt behind L/side cover ??
I can take the cover off and check it out. Thanks!
Me. It was me that had the loose bolt. Blasted thing came right out and punched a hole in the cover.
[url=https://postimg.cc/c6ZQyBpB][Image: b8c94446aa433de04e751f4ed1102524.jpg]
Holy s**t. That looks bad Huh
Nothing a little JB Weld won’t take care of Tongue
Or a new inspection window Big Grin
(09-25-2020, 09:40 PM)Lord Popgun_imp Wrote: Nothing a little JB Weld won’t take care of Tongue
Or a well used piece of chewing gum might plug the hole.
I checked today. It’s not that!
(09-25-2020, 01:14 PM)Cormanus_imp Wrote: Me. It was me that had the loose bolt. Blasted thing came right out and punched a hole in the cover.
Is that a previous battle wound, or something new?
If new, yeah like Popgun suggested, maybe JB Weld a "metal band-aid" over the hole. Oh yeah, ... a Metallica Band-Aid.
IIRC Cormanus had the cover replaced. Its posted somewhere on the board.
  Front wheel bearing noise? MagnaRider 20 1,824 03-31-2026, 08:20 AM
  Engine clicking/ticking metallic noise! WTF? Tortuga_imp 28 2,345 10-11-2024, 04:53 AM
  2014 rear wheel knocking noise dunebuggy_imp 7 971 08-05-2024, 03:33 AM
Last Post: Yata-Garasu_imp
  Front ABS Brake"Rain Stick" noise bflint 3 474 07-12-2024, 08:36 AM
Last Post: Race_ca1
  Fuel pump noise? Ben70_imp 15 1,020 07-16-2022, 12:22 AM
  Valve noise (i think) Maturecheese_imp 6 651 07-08-2022, 03:41 AM
Last Post: 1973cb750
  Brake disc rubbing noise mrded_imp 8 727 08-17-2021, 03:20 AM
Last Post: furious_blue_imp
   Ticking noise from top part of engine Kingkong_imp 40 2,860 03-18-2021, 01:22 AM
  strange start pdedse 48 2,847 02-02-2020, 06:34 AM
  Unhealthy Engine Knock / Noise spakins_imp 33 1,846 01-30-2020, 01:22 AM
Last Post: max
