side stand too short?
Neat.
The '17 stand I used to replace my too-short '14 stand is great. The lean angle looks right and it appears 100% stock. After installing it, I now know why they went with the short stand design to begin with. The longer one is only 1cm or so from the center stand foot pad when both stands are folded back for riding. It's slightly harder to deploy the center stand without also pushing the side stand down, as they are closer together now. I quickly got used to it, though, and am very happy I made the swap. I imagine the mods shown in this thread also use up most of the clearance between the stands.
(06-24-2020, 07:28 AM)Alain Lee_imp Wrote: Mine is a 2017 EX
Measured from pivot bolt center to base is 8.5 inches.
For better stability on loose/soft surface, I welded an additional "thin" metal plate to get a wider contact patch area.
It is welded offset in order to avoid contact with the exhaust pipe when in retract position.
One can add a thicker metal plate if (more length) required.
Nicely done. That looks more original and cleaner than those bolted-on ones.
(06-24-2020, 08:56 AM)bioman_imp Wrote: Inspired by the above comments I did a search (see [url=https://fortnine.ca/en/catalogsearch/result/?q=side%20stand]here) on my favorite motorcycle accessories website, and 'voila': 182 hits... Now it is just a matter of finding a stand support that fits best and that brings the bike a bit more upright. Smile EDIT: this seems more difficult than I had assumed. Does anyone know if our CB1100 shares its side stand model with other (more "regular") motorbike brands/models?
[Image: 7f4c1a7105146f9989b70ab08888a8ba.jpg]
Yes < very difficult to find the right side stand extender for the CB 1100 , only Webike had one just for our bikes.
Pictures in retract position
Very cleverly done Alain. Looks great!
Did you weld while on the bike or took it of first for safety , looks good !
Very nicely done, Alain.
Thanks gents.
Necessity is the mother of invention - I guess
No, it was welded off the bike - I did not want to take any chance with all the computers on board.
Beautiful job, Alain!! I think I will follow your advise, and get a 2017 stand.
  Center stand and new chain / sprockets jermo47_imp 8 909 04-24-2024, 10:55 PM
Last Post: jermo47_imp
  2013 cb1100 chain appears to be rubbing against center stand?? Kirbythefat_imp 4 501 05-22-2023, 12:25 PM
  Short shocks for 2013 CB1100 Griz53_imp 2 400 03-23-2023, 11:38 AM
Last Post: Griz53_imp
  ... the perfect side-stand support ? j3gq_imp 17 1,261 07-14-2022, 08:36 AM
  Happiness short-lived, looking for suggestions tod.branko_imp 23 1,562 07-12-2021, 01:35 PM
Last Post: tod.branko_imp
  center stand cj599_imp 12 971 04-17-2021, 03:03 AM
Last Post: cj599_imp
  Short distance high rev run cause lots of exhaust popping zirconxi_imp 1 254 12-10-2020, 12:53 PM
Last Post: Roper_imp
   Centre Stand 2-Parter eddi0_imp 12 910 07-29-2020, 09:36 AM
  Center Stand Doesn't Always Retract Fully emptysea 4 350 01-03-2020, 04:47 AM
Last Post: LongRanger_imp
  Pitbull Hybrid Front Fork Stand 2017EX_imp 3 354 08-26-2019, 04:49 AM
Last Post: Rocky_imp
