Short distance high rev run cause lots of exhaust popping
Good day all, due to recent pandemic lockdown, i haven't been to any ride further than 30km. Yesterday i went for a short 25km high rev (1st 2km below 3k rpm, after that 4k-7k rpm) warm up ride. My CB exhaust have lots of "mellow" popping sound when throttle off this time when compare to running long distance high rev. Its not loud and sound nice. Just wondering why i can't get it when i rode more than 50km. And will these popping hurt the CB? I kind of like it. Exhaust is aftermarket but comform to environment act.
Is the aftermarket exhaust a full system or a slip-on? Check the connections. Decel popping is caused by unburnt fuel detonating in the exhaust. This can happen when there's an air leak. When outside air enters the exhaust, it's like blowing on a hot coal--it will ignite. When you ride for longer, perhaps the hot metal has expanded enough to seal the leak. On shorter rides, there's still enough of a gap for air to get in. Check all the joins. There are many online tutorials for sealing gaps in exhaust systems. Gorilla Glue is not recommended! Wink
  'Factory' high performance spark plugs PowerDubs_imp 17 1,505 10-23-2024, 02:50 PM
Last Post: rtmoto1
  High engine revs on start up CBX1000_imp 21 1,837 06-06-2024, 02:40 AM
  TPS Sourcing because of High Idle Obi-wan Kenobi_imp 38 2,751 09-14-2023, 10:08 PM
  About the problem of high idling. (2014 cb1100ex) DDUMZI_imp 62 4,852 08-02-2023, 05:38 PM
Last Post: DDUMZI_imp
  High mileage and oil consumption Jurlie_imp 24 2,171 04-07-2023, 06:05 AM
  Short shocks for 2013 CB1100 Griz53_imp 2 395 03-23-2023, 11:38 AM
Last Post: Griz53_imp
  High idle mattmcuomo@yahoo.com 7 699 10-29-2022, 11:09 AM
   Dutch's High idle thread DutchRutter 17 1,566 09-27-2022, 01:55 AM
Last Post: DutchRutter
  Another High Idle Problem emptysea 60 4,070 07-05-2022, 11:41 AM
  Really high idle Gordo_imp 124 10,242 11-16-2021, 02:37 PM
