How To :19 tooth front, and now, a 37 tooth rear sprocket on 2013
Thanks Pauley.
Joe,
Again,thanks for doing the footwork regarding the rear sprocket. I have contacted James Alfaro to make one up for me. One question, why the counter bore, because the stock sprocket is offset???
CIP if you look at the stock gear it has a step machined into it all the way around where the nuts bolt it to the hub where the new one does not so it needs to be counter bored to accomplish the same effect without machining the gear all the way around.
I'm thinking about going in the other direction seeing as the highest top end speed I've been able to attain has been at the top of 4th gear. The bike won't go any faster at all when I shift to 5th because power is overcome by drag. I had dropped the front by 1 and added 3 to the rear of my old Tuono R, which put the top end a tad under 150 at the rev limiter in 6th gear. With that gearing it was a beast on acceleration, not to mention a real wheelie monster well into 3rd gear, especially if I had a passenger on board Wink Might be fun to play with. My FZ-1 is set up to be my bike for trips so it's not so important for the CB to cruise well.
I just ordered one of these. Is the stock rear sprocket on the CB1100 steel or aluminum? Does a steel rear sprocket really last longer? This is another great find on this forum. Thanks.
Chip
Stock sprocket is steel, which wears much longer than aluminum.
(03-22-2015, 03:14 PM)ChipBeck_imp Wrote: I just ordered one of these. Is the stock rear sprocket on the CB1100 steel or aluminum? Does a steel rear sprocket really last longer? This is another great find on this forum. Thanks.
Chip
Aluminum sprockets are popular with racers because they're lighter, but the trade-off is faster wear.
I bought an aluminum sprocket by mistake several years ago. It was the first time I'd ever seen a sprocket wear out before the chain.
I have produced many aluminum rear units, some with good and not so good results. If you are a type A person when it comes to chain maintenance, you can expect good wear, I have a number of units that are near the 10k mark. If you're like me and perform chain maintenance when i remember to, or you're hard on the throttle, then I suggest sticking with steel.
Welcome to the forum.
(03-23-2015, 06:03 AM)7thGearDesigns_imp Wrote: I have produced many aluminum rear units, some with good and not so good results. If you are a type A person when it comes to chain maintenance, you can expect good wear, I have a number of units that are near the 10k mark. If you're like me and perform chain maintenance when i remember to, or you're hard on the throttle, then I suggest sticking with steel.
Hey Jim,
Welcome
Thanks for joining and your input. Per our conversation I ended up going with the aluminum sprockets that where in stock.
  Rear indicator (Turn signal) relocation bracket 2013 model AndyBeeMD 15 1,522 08-16-2025, 05:01 PM
Last Post: bflint
  Chain and Sprocket Options? Yata-Garasu_imp 22 2,039 12-23-2024, 04:47 AM
  Chain or sprocket problem ? The Gecko_imp 14 1,256 07-30-2024, 10:05 AM
  Rear only tire on the front? mattmcuomo@yahoo.com 5 592 10-09-2023, 06:05 AM
  Front sprocket bolt cant be moved misterprofessionality 55 4,499 03-13-2023, 12:18 PM
  Front drive chain sprocket wear 1970Cadillac_imp 15 1,212 11-29-2022, 07:49 AM
  How to remove 2013 Rear ABS/Speed sensor danieljrmurray_imp 16 1,416 06-03-2022, 01:16 PM
  17 tooth CS sprocket install, comments. Bike #12_imp 11 987 01-03-2022, 08:30 AM
  Another chain and sprocket question bflint 20 1,522 10-13-2020, 01:00 PM
Last Post: tod.branko_imp
  Alloy Sprocket woes Ninemeister_imp 22 1,706 09-24-2020, 09:23 AM
Last Post: Ninemeister_imp
