Black Frame Paint
(03-30-2021, 05:20 PM)spechg_imp Wrote: I heard back from scratcheshappen.com. They say that the 2019 EX has a frame colour code of Black NH-1, but clear coat must also be applied to achieve the correct finish. Since my scratch is only on the centre stand I'll just use some Rustoleum Satin Black enamel to keep the rust at bay.
(03-26-2021, 07:32 PM)spechg_imp Wrote: Thanks everyone for your input. After a bit of research I've found a website called scratcheshappen.com. They list coloured paints for the CB1100. There seem to be several blacks:
Black Code NH-1
Darkness Black Code NH-463M
Graphite Black Code NH-B01 (as per Lord Popgun)
Matte Ballistic Black Code NH-A86M
Matte Black Code NH-105
I'll do a bit more research and see if I find out which one applies to the 2019 European version of the EX. Being a bit pedantic I'd rather use the correct paint if I can (even if it is only the side stand!).
Picture of scratch?
Is the scratch subject to oil sling from the front sprocket/chain?
Throwing my two cents in, for frame and center stand painting, I like Eastwood brand Chassis Black. It comes in gloss, which is a good match for the Honda frame, and satin, which is a good match for my Bonneville's frame. Both are very durable, but not cheap. I'm super picky about touching up little chips in the frame so I don't start to get rust blooms in the areas subject to road debris.
I use the VHT gloss black chassis paint. Very durable and will usually fade a bit to match your current shade. Get it at Oreilly Auto.
  Can I paint ABS Pulsers ? HondaLou 6 378 06-26-2026, 06:15 AM
Last Post: HondaLou
  frame gusset threaded hole question tdbru 0 220 10-27-2024, 11:27 AM
Last Post: tdbru
  Engine Cover Paint deltamark 9 758 09-05-2023, 06:22 AM
  Opinion on frame damage MxHansen_imp 29 2,098 11-16-2021, 11:46 AM
  Anybody paint their wheels black on a '13? boynton6spd_imp 2 327 06-14-2021, 11:08 PM
Last Post: MrBob_imp
  remove the valve cover from the frame (ex 2014) Enzofour_imp 20 1,288 12-02-2020, 02:06 AM
Last Post: Enzofour_imp
  Engine Paint shahyaan_imp 21 1,564 11-14-2020, 01:34 AM
Last Post: Jfro5687_imp
  Mystery dent on frame? Should I be worried? bertypower_imp 14 1,146 10-04-2020, 02:41 AM
Last Post: bertypower_imp
  Paint dave 5 445 05-09-2020, 03:59 AM
  Paint maintenance Cormanus 17 1,164 04-13-2020, 01:19 PM
