LITHIUM BATTERY UPGRADE: Ballistic vs. Antigravity vs. Shorai
(04-02-2021, 02:46 PM)E11even_Hunnit_imp Wrote: Here's the Shorai (LFX14L2-BS12) standing side by side with the stock Yuasa YTZ14S for size comparison.
Although, it's rated slightly lower at 210 CCA, it's a mighty little battery. Cranks the bike no hesitation whatsoever, everytime.
[Image: 2ab81a30cf971061d5c5e8666515a645.jpg]
... and you shave off some significant weight too.
Hi E11,
Can you post a picture viewed from the front and not from top- the Shorai in front of the Yuasa.
I just notice that the terminal polarity are reversed. Was the cable long enough?
I will have to replace mine soon.
Thanks
The difference in weight is 7.1 pounds. That's a lot but I'll save my money and just lay off the donuts for a while.
(04-10-2021, 07:23 AM)HondaFan_imp Wrote: The difference in weight is 7.1 pounds. That's a lot but I'll save my money and just lay off the donuts for a while.
It is so much harder to find a decent donut place these days.
Hi E11,
Thanks
Apologies for the long overdue response on this one, but not as active on here these days.
The original ground terminal orientation certainly was a challenge installing the Shorai. Luckily for me I built an all-custom tray/fender so I was able to make it all work, but I feel I might dig in there at some point and install a slightly longer ground cable. Hasn't been a problem in 5+ years though.
I hope I'm not jinxing myself here, but the Shorai has been awesome battery- very reliable with zero issues to report. Would recommend 10/10 despite of price increases since I purchased mine during the pandemic.
Well worthy upgrade/replacement if you can manage the potential terminal modifications.
Hi E11,
Thanks
On another note, I am using a noco nlp14 and it amazing. Been using it with no charger for over a year and no issues. I had it die the first day because I didn't have a ignition wired to my heated grips and left it on at work. I was able to jumpstart it and its been solid since. Was very good value at sub 100 dollars on sale.
  ABS , speedometer and battery Walter 10 808 05-02-2026, 01:29 AM
Last Post: Walter
  Yuasa Battery Life dave 28 2,649 04-01-2026, 04:44 AM
  2017 MY CB headlight upgrade. 17-CB-002 16 2,308 09-06-2025, 05:00 PM
  Rattle on right side exhaust / battery CB1100i_imp 4 699 04-18-2025, 02:48 AM
Last Post: CB1100i_imp
  Battery jumper the Ferret 14 1,134 10-28-2024, 10:58 PM
  CB1100 SA-E 2017 Battery Davidjill_imp 1 297 08-01-2024, 02:33 AM
  Anyone ever use these Noco lithium Batteries? mvk24_imp 20 1,724 03-25-2024, 01:52 AM
  CB1100 fuel tank upgrade johnnyH_imp 3 455 03-13-2024, 01:31 AM
  wonder battery The Gecko_imp 58 4,758 02-19-2024, 11:20 PM
  Could old/low battery trigger misfire and engine light? Motorsport3_imp 13 1,281 12-17-2023, 08:41 AM
Last Post: Jgarciajr40_imp
