Sqealing front brake
(05-12-2023, 05:31 AM)pdedse_imp Wrote:
(05-12-2023, 02:57 AM)thop_imp Wrote: I haven't posted in a long time but I was compelled to share my experience with the squealing front brake on my 2017 CB1100EX. I recall several other members had complained about the issue of the EX front brake squealing with light brake pressure applied when coming to a stop or making a slow turn. I went through all of the normal brake related cures, trying to fix the problem but nothing seemed to affect it. I tried several brake pads, coated the back of the pads with "anti-squeal" and burnished the disks with steel wool occasionally. I've had the calipers off several times during tire replacements and cleaned them each time. I also religiously "bled" the brakes every couple of years but it did not effect the noise. The bike has 38000 miles on it and had just started leaving signs of failing fork seals, so I made an appointment to replace the seal, bushings and oil. Of course, the forks have no drain plug (like my '94 BMW GSPD), and the manual does not address fork oil changes, so the oil in the forks remain unchanged until seals are changed.
After the seals were changed, I took the bike on a 100 mile shake down to make sure the seals worked and was shocked to discover the squealing from front brake was now gone. Since I never experienced the problem with my 2013, I attributed the squealing to the new dual bending valve Showa front fork. Was it the changing of the seals, or new oil, or even the bushings that effected the noise? I'm assuming it was the new oil but since I had them all done at the same time it may be open to conjecture. Ride safe...TerryRolleyes
Interesting! After reading of others having continued sqealing despite efforts, I never even tried much for my '17ex...just grew to accept it. I often wondered if it had something to do with the '17 spoke wheels, and slightly different front hub; specifically if the design is was produced a "harmonic squeal". I say this because light braking at slow speed produces a certain musical pitch, but if I then brake harder, the pitch goes down an ocatve. Maybe this summer I'll try a fork oil change and nothing else to see if I can confirm / disprove your theory.
Skipping fork oil maintenance is not uncommon, I changed mine at 10k miles and it was pretty bad. Fluid was almost dark brown and the regular color is pinkish red. I am going to change it every 5k now. It’s a pretty simple process but the forks have to be completely removed. So it’s a good idea to put a hydraulic jack under the engine so the bike doesn’t fall forward.
  Front ABS Brake"Rain Stick" noise bflint 3 457 07-12-2024, 08:36 AM
Last Post: Race_ca1
  Front brake inconsistent resistance ChiefJP_imp 16 1,365 06-14-2023, 07:46 AM
Last Post: bvictory_imp
  Front brake lever ROCK hard ichiban_imp 37 3,795 02-10-2023, 10:54 PM
  FRONT BRAKE TIGHTER omnimj_imp 2 263 09-08-2022, 02:43 AM
Last Post: 1985CB450_imp
  Front brake.... pulsating??? mattmcuomo@yahoo.com 12 762 05-11-2020, 03:51 AM
Last Post: max
  Front Brake Drag 2017EX_imp 16 965 04-10-2020, 01:22 AM
  Correct part number for front brake pads Frulk_imp 7 624 02-18-2020, 08:06 AM
Last Post: iamheero_imp
  Replaced front brake pads for 1st time at 20K miles Frulk_imp 15 1,012 01-04-2020, 02:15 AM
Last Post: Bheezy27403_imp
  How to change front brake pads 2013 abs ? 562loosenoodle_imp 20 1,218 02-04-2019, 01:47 PM
  Bike fell over, broke the front brake lever and bent the rear brake jlouis976_imp 24 1,634 09-14-2018, 12:35 AM
