Rear Brake Pedal Adjustment
On my 2014, I also lopped a couple threads off the brake push rod with a cutoff wheel. But if I were to do it again, I'd grind the brake pedal, because it's an area that just isn't necessary ever.
If the next owner of the bike wanted to raise the brake pedal back up, or even a bit higher, he might run out of thread, which has safety implications. Grinding the brake pedal would have no effect whether the pedal is high or low.
Agreed. If they had made the pedal with more clearance, it never would have been a problem. But sometimes, they design it one way, they don't consider owner's preferences and what we might do. In other words, they can't test for everything.
Including the little caveat "make sure the clearance....does not fall below 1mm."
may have been their fix after they found a potential interference problem, rather than redesigning a part.
Well, looks like they tried to get sexy and hide the rear master cylinder behind the foot rest assembly, which wouldn't leave much room for adjustment.
But it looks nice, right?
  Valve Adjustment Shims dave 13 646 07-28-2026, 12:49 PM
Last Post: MagnaRider
  Valve Adjustment and Camshaft Removal dave 5 606 03-21-2026, 04:49 PM
  Valve Adjustment dave 6 851 08-29-2025, 10:46 AM
  Rear brake pad replacement LongRanger_imp 39 3,461 05-03-2025, 10:45 AM
Last Post: Delphisa
  Valve Adjustment Intervals CBRider_imp 32 2,779 04-21-2025, 02:24 PM
Last Post: Jurlie_imp
  Valve Adjustment Tolerances - How Far Do You Go? dave 14 1,473 10-18-2023, 09:28 PM
Last Post: The Gecko_imp
   Rear brake pedal Mixagon_imp 28 2,122 08-06-2022, 07:29 PM
Last Post: Mixagon_imp
  Rear brake pad thickness. 17-CB-002 4 438 06-18-2022, 12:42 AM
Last Post: 17-CB-002
  Front forks adjustment Olyrider 5 475 05-16-2022, 11:04 PM
Last Post: Sparky80_imp
  Mirror Adjustment Question deltamark 14 1,274 03-12-2022, 03:53 AM
