removing tank stickers
Well, they are tacky, but I'll take them if they help avoid a rear ender. I'm still thinking about adding a flashing brake light of some sort.
Yep hair dryer worked, Prepsol for remaining adhesive, coat of wax=more shiney red paint Thanks
Has anyone tried removing the pinstripes from the tank? I would like to remove mines
My bike didn't come with those stickers. I need to buy a set. I'd prefer to hang on to that "new car feeling" for as long as possible!
(04-03-2016, 03:24 AM)jsinher3_imp Wrote: Has anyone tried removing the pinstripes from the tank? I would like to remove mines
Dont think thats possible. And why would you?
I didn't use anything other than my fingernails to get the peeling started. Came right off. Maybe a bit of residue that I got rid of with Honda Cleaner Polisher.
They're painted on the tank. Not removable.
They are actually decals that are clear coated over. They are available and shown in the MARK section of the parts fiche.
Hand held hair dryer worked fine for me. As mentioned, keep it moving and test the decals gently with your fingernail until the glue is soft enough to peel away. Sometimes you can get the edges peeled off but have to give the center of the decal extra heat to soften that up. Works great.
(04-03-2016, 10:12 PM)Supervillian_imp Wrote: Hand held hair dryer worked fine for me. As mentioned, keep it moving and test the decals gently with your fingernail until the glue is soft enough to peel away. Sometimes you can get the edges peeled off but have to give the center of the decal extra heat to soften that up. Works great.
Exactly how I did it.
I cleaned off any residue with a mild solvent and then finished with some regular car polish.
As long as the stickers stay in good condition you can leave them on if that's what you want to do, but if they deteriorate and are eventually removed the pristine paint under the stickers will be in pretty sharp contrast to the slightly faded paint of the tank.
That's why most of us get rid of them right away.
OTOH, you could buy a set of new stickers and replace them if the old ones fail over time.
I suppose it all depends on how long you intend to keep the bike and if it's exposed to a lot of sun.
I'm the epitome of anal Big Grin when it comes to my "toys" so my bikes are always inside and out of the sun except when I'm out on the road.
  A question,or theory about removing engine covers. FLYTYM_imp 4 524 11-10-2020, 02:48 PM
Last Post: Bazbro_imp
  Whitehouse tank dimensions vs CB750 tank dimensions spartanheed_imp 2 401 04-27-2019, 05:40 PM
Last Post: spartanheed_imp
  Advice on removing Honda and CB1100 badges ManInBlack_imp 7 687 08-16-2017, 10:48 AM
Last Post: ManInBlack_imp
  Removing seat pittycheria_imp 20 1,698 06-15-2017, 03:10 PM
   Video: How to Remove Tank Stickers EarsOnWheels_imp 8 645 07-24-2015, 01:53 AM
Last Post: DaSwami_imp
  Tank Stickers SlyvesterZ_imp 12 1,014 07-13-2015, 06:39 AM
Last Post: specialist8
  Stickers on tank? HikerToo_imp 14 1,101 06-04-2013, 11:51 PM
Last Post: meowguy_imp
