What to use cleaning rear wheel chain grease?
(05-05-2014, 04:33 AM)The ferret_imp Wrote: Wd 40 on a rag
All I gotta say is WOW! and thanks for the cleaning tip. I hadn't cleaned the rear wheel yet and it was severely coated with dirt and grease thrown from the chain. I got out the WD-40 and a towel and expected to work at it. Was I surprised when all I had to do was spray or wipe on, and it all melted off. A quick wipe with the towel and it was shining and spotless!
Yeah, WD on a rag on the rear wheel takes all the grease/gunk right off too!
I agree with wd40 and simple green. I started using the simple green this year and it works well.
To check back in on my own thread, I have to say that I was amazed at how well and easily the WD-40 worked. Almost frickin' magically, to be honest!
Yeah, and unlike wheel cleaning products that say after using you have to rinse it thoroughly with a forceful hose stream, if a light film of WD-40 is left behind after wiping with a rag, so what? It's a good thing.
After trying a lot of different stuff on wheels ( because when we had the store I was changing about 10 tires a day) and I always
cleaned up the wheel for the customer I found that air filter cleaner used on dirt bike filters worked fast and did not leave a film and is safe on rubber and plastic. When I would get a real bad one I would take the tire off and then take the rim to the sink and use S100
wheel cleaner. - It kept the customers coming back!
(05-05-2014, 04:45 AM)redbirds_imp Wrote: Both WD-40 and Kerosene work well. Plexus or the Honda Clean & Polish work great for adding a bit of shine. I use Dupont chain lube and never have any trouble with fling. I cleaned off that goop that Honda put on the chain as soon as I got mine home from the dealer.
My three favorites as well. In fact, that Pro Honda Cleaner/Polish is sex in a can. I love going out and slathering it up...then the slow but urgent polishing...finally left with a glowing and glistening finish.
ROFL
The problem with WD40 near the rear wheel is you have to make sure you don't get any on the tire. I prefer brake cleaner to get rid of that mess.
I didn't find it at all difficult to keep it off the tire.
  Cleaning the Exhaust Pipes ahm12_imp 16 1,180 05-10-2019, 12:12 PM
  A question about wheel weights. FLYTYM_imp 24 2,117 12-01-2018, 03:55 AM
Last Post: Jim21680_imp
  Trailer wheel chock Buff7mm_imp 4 430 05-10-2018, 08:57 AM
Last Post: Buff7mm_imp
  Wheel exchange Gravity Storm_imp 20 1,502 09-18-2017, 12:38 PM
Last Post: Stichill
  How common are wheel & suspension upgrades? Syscrush_imp 8 730 08-09-2017, 12:22 PM
Last Post: 736cc_imp
  Spring Cleaning ecka00_imp 7 598 03-30-2016, 08:53 AM
Last Post: ryanschillinger_imp
  Design Problem, Rear Wheel shifting to left mockhoff_imp 35 2,625 12-10-2015, 03:53 AM
Last Post: emptysea
  What methods/products do you use for cleaning your windscreen? CBryder_imp 11 780 09-16-2015, 02:29 PM
Last Post: emptysea
  Front Tire Wheel Chock linuxology_imp 1 238 01-11-2015, 06:45 AM
  wheel lighting on my cb1100 jungkiwenas_imp 18 1,234 11-09-2014, 07:32 AM
Last Post: furious_blue_imp
