Cleaning the Exhaust Pipes
Hello Everyone
Can anyone recommend best solution/product for cleaning the exaust ?
I am seeing 3 things on my exhaust blue coloration, gold coloration and grey spots. What are these grey spots ? i use bluejob powder which seems to be working as you can see in the picture but i feel like i should be using something else get rid of these grey spots first. Sorry i am not very good with this stuff. If bluejob is the only solution looks like its going to take me forever.
Thank You,
Start here and read a number of the posts after it: http://cb1100forum.com/forum/showthread....#pid231508
You’ll find this subject is like an oil thread Smile
If you've got the steel pipes on a '14 model, I can give you my regimen.
spray down with OptiGlanz
https://www.louis.eu/artikel/optiglanz-c...l/10004155
and follow the directions on the bottle. flush with clean cold water afterwards until completely clean, then wipe down dry with clean cloth or rags.
next, apply Generous dollops of Mothers polish
https://shop.advanceautoparts.com/p/moth...lsrc=aw.ds
on a green scotch brite pad, generous elbow grease until you see the black polish residue appearing. wipe everything off completely clean with clean dry towels or rags. repeat if the polish was not complete, but you should get a gorgeous factory-new-like steel finish.
(04-15-2019, 10:15 AM)misterprofessionality_imp Wrote: If you've got the steel pipes on a '14 model, I can give you my regimen.
where did you buy optiglanz in US ? looks like the right product
well, officially, i didn't buy it in the US, i ordered it online from Germany. Well worth it though, that stuff is magic. works wonders on your collector too.
Yoshimura Stain Magic. No scrub pads. No elbow grease. Less than an hour. Have a drink ready. Let it act for 15 minutes, and then use a bit of wrist action.
Optionally, follow-up with your favourite metal polisher. This will provide the mirror-like finish. I use a product called Peek.
But as popgun indicated, this is one of many places to look:
[url=http://cb1100forum.com/forum/showthread.php?tid=3268&page=481]http://cb1100forum.com/forum/showthread....8&page=481
Autosol and an old sock or t-shirt. Like GUNK degreaser, bikers have been using Autosol for more than 60 years. Wear nitrate gloves as anything this nasty can't be good for your skin. It also turns the sock black.
Draw a line of Autosol down the header and spread it with the sock. Leave it sit for a few minutes. Wrap the sock around the header, twice if it is long enough. Grab the ends of the sock and rotate it back and forth around the header, moving it slowly up and down as you do.
Learned this when I bought my first 650cc BSA Lightning in 1967. Never found anything else that would remove the blue and toasted bugs as well.
Autosol has been my go-to cleaner for many years, but I am always willing to read the experiences of others and learn.
Autosol and seesaw action with a long cloth works well, but anything that does not require effort looks appealing ROFL ROFL ROFL
I ordered Yoshimura Stain Magic will see
(04-16-2019, 01:21 AM)ahm12_imp Wrote: I ordered Yoshimura Stain Magic will see
Remember to shake well before use. Wear gloves and eye protection. Best at reasonably warm or better air temperature. Apply, let stand for maybe 15 minutes, then rub off. You may need a second application. In terms just of the headers, one tube should last for many years.
  Shined up Exhaust Pipes TwoBrothersBusa_imp 20 1,381 02-20-2022, 02:37 AM
Last Post: 2017EX_imp
  Polishing up the pipes Tom_imp 95 7,417 12-15-2021, 04:05 AM
   In Praise of Quiet Pipes Yata-Garasu_imp 48 3,999 12-03-2021, 09:49 AM
  Alternatives to Stock 4 into 1 Header Pipes? Yata-Garasu_imp 16 1,282 05-17-2021, 09:38 PM
  Brits To Tackle Loud Exhaust Pipes With Noise Cameras clearviewx 46 2,885 06-10-2019, 05:01 PM
Last Post: Bazbro_imp
  Discolored exhaust pipes ohiorider_imp 19 1,837 12-11-2017, 09:28 AM
Last Post: Northrider_imp
  Discolored pipes zippooriginal_imp 15 963 07-28-2016, 12:45 PM
Last Post: 4 Paws_imp
  What to use cleaning rear wheel chain grease? Papa Weeley_imp 47 4,199 07-14-2016, 02:58 AM
Last Post: Papa Weeley_imp
  Spring Cleaning ecka00_imp 7 567 03-30-2016, 08:53 AM
Last Post: ryanschillinger_imp
  What methods/products do you use for cleaning your windscreen? CBryder_imp 11 741 09-16-2015, 02:29 PM
Last Post: emptysea
