Removing seat
Thanks Flynrider, the video helped. So the trick while have the key turned ,pull seat up and back using the seat strap , not the back of the seat. You need to yank hard. Hope the strap does not break ! - anyway I am all set
It will probably loosen up some as latch parts wear in.
I lift mine back and up with the back of the seat.
To replace it, the tab at the front and hooks in the middle must be pushed into their holders. I hold the front of the seat down and give the back a good thump forward and down. The rear seldom locks first try, but another thump usually puts it right.
The techniques for removing and installing the seat on my CB500XA were similar. Although it was a bit harder to line up the front tab because it was much smaller.
(06-12-2017, 02:13 PM)Nortoon_imp Wrote: Might be silly of me, but did you leave the key in the seat lock? It's something like the gas cap lock. You have to leave the key in it until you are done.
Wait till you have to put the seat back on. I had lots of practice with my CB500XA, so this seat is not too hard for me to lock down.
The toughest thing for me is the putting this porker on the center stand. I weigh 220 pounds and have 26 years of experience putting a dozen different motorcycles on their main stand without a problem. But for some odd reason this one tends to lean towards the rider. Which of course is much better than having it pitch away from you. But both feet of the stand must be firmly planted to hoist this oinker to her position of rest.
You shouldn't have to hoist anything. Both feet of stand touching ground, yes. Then grab left handlebar with left hand, foot on peg and push down while at the same time pulling up on the grab rail with right hand. Mine goes right up without too much effort.
https://www.youtube.com/watch?v=OwXZyJSPkx4
Hoist was a poor choice of words.
The method you describe and we see on YouTube is exactly what I use and have used on of the motorcycles I have owned over my 26 years of riding. Despite being considerably heavier than my EX, my Goldwing rolled on and off the stand easily. But this new machine is difficult.
That's interesting Nortoon as most of us have found the 2010-2014 models to be surprisingly easy for the size of bike. You certainly have to have both feet of the stand on the ground, though.
I wonder if the 2017 bikes are subtly different in how they pop up onto the stand?
It's certainly not the easiest bike I've owned to get on the centerstand. I struggle a little with it. My 750 Nighthawk jumped on it's centerstand by itself in comparison. The ST on the other hand is so hard for me, the only time I use the centerstand is when my wife is there to help me.
(06-13-2017, 06:01 PM)Cormanus_imp Wrote: That's interesting Nortoon as most of us have found the 2010-2014 models to be surprisingly easy for the size of bike. You certainly have to have both feet of the stand on the ground, though.
+1, I find my 2013 pops up on the center stand with very little effort however, my brother has a hard time with his 2014 CB. Go figure?
I checked some side stand part numbers.
2013 Standard 50500-MGC-000
2014 Standard 50500-MGC-306
2014 Deluxe 50500-MGC-305
2017 EX 50500-MGC-JBO
I can understand the difference between Standard and the Deluxe or EX model because of the muffler(s).
Odd that the Standard model stand would change year to year.
I guess I will have to wait for other EX owners to chime in.
Maybe I'm just not tough enough to own a Honda.
Or maybe it's just the way I hold my tongue. Tongue
Agreed! Last weekend I changed the oil on both CBs and put them on their center stands side by side before I started. The CB750 took substantially less effort than the CB1100 (although neither was particularly difficult). The bikes weigh within 30 lbs of each other, so I suspect the difference is probably more related to the center stand geometry.
  A question,or theory about removing engine covers. FLYTYM_imp 4 524 11-10-2020, 02:48 PM
Last Post: Bazbro_imp
  Advice on removing Honda and CB1100 badges ManInBlack_imp 7 687 08-16-2017, 10:48 AM
Last Post: ManInBlack_imp
  2013 STD seat vs. 2014 DLX seat VTR1000F_imp 24 2,180 07-06-2016, 10:51 AM
Last Post: Offroad
  removing tank stickers justinrhenry_imp 22 1,541 04-04-2016, 11:23 AM
