Ohlins Piggy-backs Installed
The Spaceman_imp Offline
Threads: 42
RE: Ohlins Piggy-backs Installed
(08-25-2013, 12:32 PM)jodyz_imp Wrote:
(08-24-2013, 09:57 AM)The Spaceman_imp Wrote: The shocks look very nice. Being Ohlins, I'm assuming you spent $6,4899.99 on them. Per side.
Yamaha's new Bolt blobbler comes with piggyback shocks if you order the upgrade version. I wonder if they'd fit...
With only about 3" of travel... doubt it.
Just kiddin... If I read one more Sportster/Bolt "comparo" article, I'm going to puke!
08-26-2013, 07:57 AM
lola_imp Offline
Threads: 18
(08-25-2013, 12:48 PM)Mikey350D_imp Wrote: Bad NewsAngry
I started to get a very slight rub on the brake side.
Not enough clearance between comp knob and grab rail.
Every looks OK when I'm off the bike, but under load...
So I'm going to play if safe and abandon stock grab rails,
get some new rear lights and fab new rails.
the connections of the rear turn signals are underneath the tray compartment, Just remove that and the connections are Orange and Sky Blue for the turn signals.. Once you have the wires disconected you can just remove the grab rails with a number 6 allen wrench. Now you could still use the stock turn signals by mounting them on the rear bolt hole for where the grab rail connection use to be...... As far as grab rails go you can use the Active Grab Rail which sit higher than our stock ones. http://www.acv.co.jp/products/00444
just a tip...
08-26-2013, 09:33 AM
Mikey350D_imp Offline
Threads: 4
just a tip...
just a tip...
Thanks or the tip. I am also going to experiment with some aluminum flat or angle stock, to see how it looks. But the moral of the story is you'll need different grab rails (or none) with piggybacks
08-28-2013, 05:38 AM
Ack-CB11_imp Offline
Threads: 46
I'm surprised about the install trouble. On the web I've seen them on our bikes. With Hyperpro having a working set, you would think they would have something too?
08-28-2013, 06:21 AM
silascopathic_imp Offline
Threads: 28
why don't you turn them upside down? it just a spring after all. i have seen that done on bikes before
08-28-2013, 10:10 AM
  Has anyone installed a louder horn? Doug Shepard_imp 36 2,772 01-29-2024, 05:14 AM
  Öhlins front fork Yama_imp 4 424 06-28-2023, 09:43 AM
  I installed the Emgo Reverse Cone Universal slip on danieljrmurray_imp 2 390 05-15-2023, 04:29 AM
Last Post: 3rd Gear Steve
  Nitro Piggy Back Shocks touchetteweb_imp 3 382 03-29-2022, 12:39 AM
   Traxxion AR-25's installed... great upgrade!! Sparky80_imp 2 340 10-18-2021, 12:38 AM
Last Post: Sparky80_imp
  Hepco & Becker Luggage Installed CaptainChris_imp 61 4,005 12-12-2020, 11:51 PM
  Anyone installed a radiator cover? bioman_imp 35 3,757 05-18-2020, 12:00 PM
Last Post: TXBikerGuy
  So, What's the deal with bar-backs? Rexburgtom_imp 3 378 02-18-2020, 03:29 AM
  Givi Sport Bag installed on 2017 RS OEM Rack Mitch_imp 17 1,223 07-31-2019, 02:39 AM
  Road Comet installed ! greekcb_imp 10 893 06-03-2019, 06:14 AM
Last Post: glennrcompton_imp
