Road Comet - Fine Tuning
Ridem32_imp Offline
Threads: 51
Cb4me. Same way mine bolts. Mine is rigid. But maybe because I used the top W/S strip around my headlight and it made it a very snug fit. Mine does not move at all
05-27-2014, 12:09 AM
CB4ME_imp Offline
Threads: 183
RE: Road Comet - Fine Tuning
(05-27-2014, 12:09 AM)Ridem32_imp Wrote: Cb4me. Same way mine bolts. Mine is rigid. But maybe because I used the top W/S strip around my headlight and it made it a very snug fit. Mine does not move at all
My next purchase will be a 2013 Road Comet II with stripes. I'm going to paint the inside and use truck trim for the headlight and the black trim for the top of the shield (although I like the screen without the trim too).
I'll be posting a road comet I for half price.
05-27-2014, 12:32 AM
Ridem32_imp Offline
Threads: 51
That's a deal at half price! If I had a 13 model I would buy it.
05-27-2014, 12:33 AM
Huladog_imp Offline
Threads: 23
Used your tip about inserting some kind of soft support between the gauges and the interior edge of the fairing to stiffen it up. I've been watching my fairing move around for months and kept trying to think of ways to reinforce it, then I just tried your simple solution using some dense black packing foam I had laying around. Cut a couple of narrow rectangles, squooshed them into place and the fairing was now stable with the standard low wind screen.
Makes sense since my Puig windshield came with two neoprene discs to stick on the sides of the gauges to provide support (I've left them stuck to the gauges so I can swap to the Puig if needed again).
Now I just swapped out the low wind screen and put back on the taller touring screen with the flip-up. Had taken it off since the fairing really moved around a lot with the taller screen. Will see how it works.
Also, I started to get stress cracks around two mounting holes in the clear low screen which made we re-think how I was using those tiny plastic washers that comes with the Road Comet fairing. I was getting rain water stuck between the fairing and the inside of the screen, too.
I figured somewhere along the way I had moved the washers from between the screen and the fairing where they provided a small gap and cushioning, to the outside of the screen under the head of the mounting screws. Don't know why I did that, but duh, probably why I got those stress cracks, duh.
Aloha,
Huladog
06-01-2014, 07:00 AM
Red Mist_imp Offline
Threads: 12
Nice lineup of bikes there.
06-01-2014, 08:56 AM
Butch_imp Offline
Threads: 1
Like to know where you got the small box on the back thanks butch
09-01-2014, 06:19 AM
ClassicVW_imp Offline
Threads: 6
I installed my clear washers just under the bolt heads against the screen plastic. The bolt heads don't look too much larger than the holes in the screen plastic so it looked like the correct way.
I also added a non metal washer for some cushion on the bracket under the fairing that attaches to the horn bolt. The under fairing bolt, not the horn bolt.
The metal bracket directly on the thin fiberglass tab at the bottom of the Comet didn't give me much confidence it wouldn't crack.
09-01-2014, 06:36 AM
  power port and Samurider Road Comet Fairing 1 tdbru 9 1,064 05-04-2025, 07:20 PM
Last Post: tdbru
  Road Comet Masqeroad: A Beautiful Pragmatic Response rdprdp01 7 1,100 05-04-2025, 11:33 AM
Last Post: rdprdp01
  Road Comet: A Beautiful Pragmatic Response rdprdp01 12 1,133 10-29-2024, 12:25 AM
Last Post: rdprdp01
  Wanted. Chick design comet 2 windshield Nightryder22_imp 15 1,354 01-22-2023, 03:07 AM
  Road Comet Fairing Catbird_imp 47 4,660 08-16-2022, 10:33 PM
  No more tuning CB1100?? gretle_2.0 31 2,427 05-27-2022, 06:08 AM
   Road comet 2 fitment correct?? gretle_2.0 8 921 05-07-2022, 11:08 PM
  Tall Riders and Comet striped shield Nightryder22_imp 11 1,169 04-08-2022, 09:28 PM
  Don Guhl No Longer Tuning Motorcycle ECUs tj_gee_imp 45 3,425 03-08-2022, 02:48 AM
  Road Comet 2 Impressions Frulk_imp 12 984 11-14-2021, 07:09 PM
Last Post: mrded_imp
