Well well well; hello everyone! I have good news (at least in my case). Like many others, I was having idle problems and bike shutting off when stopped at a light or while riding. After reading all the discussions here, I decided to change the iacv myself without ant troubleshooting(I know its crazy but didnt want yo spend hours troubleshooting). So I boight the part and with the help Ingot my hands on a service manual. So I took apart the seat, tank, left and right covers; the rear air filter housing and for the life of me, I couldnot remove front air filter housing that is attached to throttle control. In the effort to do all these, I had disconnected the battery and most harnesses including the computer. So I decided to put everything back and accept defete and take the bike to a shop for repairs. I put everything back and to my surprise the bike was fixed by just disconnecting all the parts and letting it sit for a few days... guys; if you have the same issue; try this; it may help!
(09-23-2024, 05:03 AM)Cbman_imp Wrote: Well well well; hello everyone! I have good news (at least in my case). Like many others, I was having idle problems and bike shutting off when stopped at a light or while riding. After reading all the discussions here, I decided to change the iacv myself without ant troubleshooting(I know its crazy but didnt want yo spend hours troubleshooting). So I boight the part and with the help Ingot my hands on a service manual. So I took apart the seat, tank, left and right covers; the rear air filter housing and for the life of me, I couldnot remove front air filter housing that is attached to throttle control. In the effort to do all these, I had disconnected the battery and most harnesses including the computer. So I decided to put everything back and accept defete and take the bike to a shop for repairs. I put everything back and to my surprise the bike was fixed by just disconnecting all the parts and letting it sit for a few days... guys; if you have the same issue; try this; it may help!
Cbman, the IACV is not the problem. It is a lot easier to install a new ECU and solve the problem once and forever. My 2013 ran okay for a week or so after I got the new IACV, but then the problem returned. Only when I put in the new ECU did it idle like a new bike. I hope your problem is resolved, but, if it returns, get a new ECU. The intake air control valve (IACV) probably is not your problem. Good luck with this.
I am amazed that after over eleven years, and dozens of owners experiencing this exact same problem, that Honda hasn't figured out the root cause. I replaced my IACV eight years ago and never experienced the problem again. However, there are forum members who have replaced their IACV and this did not solve the problem for them. Some forum members report that ECU replacement is the only solution, and some forum members from Europe have reported that an ECU reflash cured the problem for them. Honda America will not reflash an ECU. The fact that Honda doesn't even acknowledge the problem doesn't speak well for them.
Cbman. Report back to us in a month and tell us if your idle issue has been permanently fixed. My bet is it isn't, but good luck.
It is worth mentioning that the ECU I bought from Partzilla had a different part number. No one listed the ECU with the original part number for the 2013. Problem is that wasn't the only year with the problem, so I don't know what happened. I know one of our members in South Korea took his to his Honda shop and they solved his fast idle problem by replacing the ECU. That is why I replaced my ECU.
From the 'Old' Forum yesterday:
Fabrimtb Wrote:Hi guys,I live in Europe, my CB1100 is a 2013 model with ABS. After suffered the problems related to the idle instability, today my bike has been updated with the last version of the ECU software, ECUID 0101390102. I hope this can help you.
Hi guys, as I wrote in the "old forum', one month ago after read on the web that in Germany an ECU update is available, I asked about it to the local Honda dealer. Officially there is no info about it, on my request the technician connected the PC to the ECU. He found an available update, but at the same time he meet an error on the TPS, he tried to reset it without any result. After did the update, he was able to do the reset. Since then, I did more than 400 Kms, it seems the bike is ok. I hope it will last and help you.
(08-20-2026, 10:48 AM)fabrimtb Wrote: Hi guys, as I wrote in the "old forum', one month ago after read on the web that in Germany an ECU update is available, I asked about it to the local Honda dealer. Officially there is no info about it, on my request the technician connected the PC to the ECU. He found an available update, but at the same time he meet an error on the TPS, he tried to reset it without any result. After did the update, he was able to do the reset. Since then, I did more than 400 Kms, it seems the bike is ok. I hope it will last and help you.
That is an interesting development.  Had this been U.S. available back in 2017, I would likely still have my '14 standard.  But I can't complain with the second go-around on the EX '17.
  idle problem update 1973cb750 37 2,178 05-12-2026, 08:38 PM
Last Post: rdprdp01
  Public Service Announcement - Speed Sensor Clip Gone in 60 7 929 10-22-2025, 02:11 PM
  Idle a little rough and miss fire when revved johnnyH_imp 3 443 09-15-2024, 12:16 AM
  Chain or sprocket problem ? The Gecko_imp 14 1,378 07-30-2024, 10:05 AM
  another idle thread Tom_imp 11 1,073 11-20-2023, 01:30 PM
  O ring chain problem Mixagon_imp 7 692 10-17-2023, 07:28 AM
  TPS Sourcing because of High Idle Obi-wan Kenobi_imp 38 2,951 09-14-2023, 10:08 PM
  Honda CB1100 Rough Idle Solution dickie1951_imp 56 4,607 09-06-2023, 01:36 AM
  About the problem of high idling. (2014 cb1100ex) DDUMZI_imp 62 5,222 08-02-2023, 05:38 PM
Last Post: DDUMZI_imp
