For all the work I went through to replace the IACV (I followed the Honda service manual and removed the entire rear fender to allow clearance to remove the airbox) I would have prefered to replace, or reprogram the ECM, but the reprogram option wasn't available five years ago, and I had no information available then that replacing the ECM would work. My bike was examined by an authorized Honda dealer at that time, under warranty, and they performed a computer diagnosis that didn't find any errors. As luck would have it, the problem was not present when I delivered the bike to the shop.
[/quote]
you did this?
[Image: c7c1f623802153ac2117d3bace683bc4.jpg]
[Image: 250b6739f6c2f150fd5a142a68982c98.jpg]
I disassembled lessSmile
[Image: 12c1d81680c001422f079d7823347163.jpg]
(07-20-2023, 03:01 PM)max_imp Wrote: Just posting some images for Peter here, just ignore for now please;
Headlight bucket test probe;
Cheers max
Ok moderators, I am done with this diagram and it can be deleted to comply with the regulations.
Thanks
Beer
How much forcing and bending to the air box did you have to do to get it to squeeze out? I was afraid I would break the air box if I tried to force it out.
It continues to amaze me that so many people in so many parts of the WORLD with so many different model and years of this model of Honda motorcycle have had this similar problem and Honda has completely ignored it.
[/quote]
Does anyone know if Honda "secretly" released a service bulletin to its dealers with instructions for repairing the idle issue? I don't know what the name for it is, but basically the manufacturer keeps all information about the problem quiet, and never releases any information to any of the unsuspecting customers. In this case it looks like the secrete service bulletin would be a replacement of the ECM with the new (updated) part number.
I know there was never said anything to US dealers. My tech would have told me.
Cheers max
Max , sorry for late response, here are the results:
Conditions:
2014 CB1100 Std, fully charged battery at 12.5V, red killer switch in "kill" position
black-10 pin connector/double row of 5 pins
wires: white to red-white
[Image: d3b8e38d98f9aafade00602d6f776c36.jpg?1]
* ignition OFF = NO voltage
[Image: e199dba576fe331c50ea84b1d09356ef.jpg?1]
* ignition ON = 9.8V
* engine running = 12.5V
PB,
No Flukes in Canada? Tongue
(07-27-2023, 12:58 AM)Lord Popgun_imp Wrote: PB,
The last one was shipped to Virginia, Norfolk area Tongue
Peter thanks very much for measuring this very precisely and well documented,
This is likely the " keep alive " supply that supplies voltage to the ecu's memory when the ignition is switched off.
It could be used to simulate a " battery reset " every time the bike is switched off for some time and maybe aid in solving the ii issue.
It would require a small relay in line with this wire which is energized when the ignition is switched on and de-energized ( off ) when the ignition is switched off.
All the wiring is accessible inside the headlamp bucket to do this modification if someone would try this out in favour of replacing the ecu.
Any thoughts on this procedure?
NP. ... when you asked me to do that test, I already new what your plan was.., very smart Beer
(07-28-2023, 08:13 AM)peterbaron_imp Wrote: NP. ... when you asked me to do that test, I already new what your plan was.., very smart Beer
Yeah so please ignore the pm reply, i read the result wrong the first timeWink
Boy that was quick!!
  idle problem update 1973cb750 37 2,131 05-12-2026, 08:38 PM
Last Post: rdprdp01
  Public Service Announcement - Speed Sensor Clip Gone in 60 7 869 10-22-2025, 02:11 PM
  New speed meter replacement ACE_IRA_imp 3 524 02-13-2025, 06:25 AM
  Idle a little rough and miss fire when revved johnnyH_imp 3 424 09-15-2024, 12:16 AM
  Chain or sprocket problem ? The Gecko_imp 14 1,260 07-30-2024, 10:05 AM
  another idle thread Tom_imp 11 1,003 11-20-2023, 01:30 PM
  O ring chain problem Mixagon_imp 7 656 10-17-2023, 07:28 AM
  TPS Sourcing because of High Idle Obi-wan Kenobi_imp 38 2,690 09-14-2023, 10:08 PM
  Honda CB1100 Rough Idle Solution dickie1951_imp 56 4,242 09-06-2023, 01:36 AM
  About the problem of high idling. (2014 cb1100ex) DDUMZI_imp 62 4,796 08-02-2023, 05:38 PM
Last Post: DDUMZI_imp
