Poll: How many are having problems with rear Brakes?
My rear brake works as expected--- 8K miles no issues VIN 1427
12,000kms and not a single problem. After bleeding the system it's performance did get a lot better (though it was easily satisfactory before).
2013 Standard#00021 non ABS rear brake with 4K+ miles works exactly like it's supposed to.
2014 Standard, rear works ok; better than my Tuono but not as good as my Yamaha Bolt XV950. I use the rear (and front) when coming to a stop (that's how I was taught). I also use the rear to scrub off a few mph before a turn (like Ferret mentioned), also for extreme slow speed (crawling) maneuvering. When lane splitting/filtering at lower speeds, I cover the rear brakes at all times, just in case.
No complaints with my 2013 STD.
2013 STD and I've been getting a bumpy feedback when I'm braking with the rear at lower speeds. I'll be going 35 slowing to a stop at the light and at around 20-15mph, I'll get a very spastic response from the rear brake that I feel in my foot. Has bleeding the line been one of the better approaches to resolving this issue?
Specialist,
Those of us with rear brake problems pretty much cleared them up by bleeding them. And there was air in the line. Mine had a lot.
I read this whole thread and I haven't heard anyone say they felt a spazzing of the pedal like I do. My rear brake actually works fine regarding stopping power, I can engage it and slow down but the vibration of the pedal makes me worried about using it too much.
(11-04-2015, 07:21 AM)specialist8_imp Wrote: I read this whole thread and I haven't heard anyone say they felt a spazzing of the pedal like I do. My rear brake actually works fine regarding stopping power, I can engage it and slow down but the vibration of the pedal makes me worried about using it too much.
This same kind of "pulsing" you are describing has happened to me with some of our cars. It usually means that a brake rotor is thicker and thinner in various places around the rotor, thereby causing the pulsing sensation. With cars the mechanics typically machine the rotor to true it up into a plane again. Not sure if this is possible with smaller, more delicate MC brake rotors.
Good luck in sorting things out!
fritz
Fritz,
Ya know, that is a good possibility (And I did just have that happen on my car and they just turned the rotors and put on new pads).
I had 'air in the lines' of the brain, I guess. I think a member did have a rotor problem and posted about it. I THINK the dealer replaced the rotor under warrenty. I'd have to do some searching to be sure though.
This may be the thread. It shows and talks about a warped rear rotor. http://cb1100forum.com/forum/showthread....rped+rotor
  Front brakes squeal...this feels like a saga in the making VLJ_imp 108 10,119 11-17-2021, 04:33 PM
Last Post: j3gq_imp
  2020 Poll - forum member age Guth_imp 100 8,027 04-22-2021, 01:36 AM
  Problems with the website Randy B 17 1,253 03-13-2021, 12:21 PM
  motor cycle magazine subscription problems Houtman_imp 4 494 01-02-2021, 12:21 PM
  imgur problems? pdedse 2 330 09-17-2019, 04:07 AM
  Common problems experienced with CB1100 on road? run-tmc_imp 28 1,829 05-28-2018, 08:04 PM
Last Post: DaSwami_imp
  ADVrider poll on classic motorcycles pdedse 44 3,020 11-29-2017, 02:51 AM
Last Post: SportsterDoc
  02 sensor eliminator poll TCBronson_imp 15 1,183 08-28-2017, 05:41 AM
Last Post: Toddman_imp
  2017 CB1100 EX ABS brakes 17-CB-002 5 390 06-11-2017, 12:07 PM
Last Post: 17-CB-002
  Anti lock brakes Mikestib1_imp 29 2,288 01-08-2017, 02:54 PM
Last Post: flynrider
