(10-28-2019, 08:58 AM)pdedse_imp Wrote:
(10-28-2019, 08:09 AM)SportsterDoc_imp Wrote:
(10-28-2019, 02:35 AM)The ferret_imp Wrote: Hard to believe it's been 14 months doc. Helicopter? I know a guy that became a helicopter pilot. He said keeping those things in the air is a real chore.
Yep, probably more risk than motorcycling, but I made wife and extended family a promise about motorcycling, but not about aviation...which they are supporting.
On a Robinson R22, a simple and common two seater, if the engine loses power, despite typical aviation dual ignition systems, the window to disengage the clutch, to avoid freefall, is only about 1.6 seconds, due to low enertia rotors.
Basic controls
https://m.youtube.com/watch?v=mC8KxV0chhI
Are those instructions written on the back of the instructor's hand at the 1:48 mark?
Huh
Huh
LOL...and I tried getting us back on topic!
Basic controls
Huh
Huh
Yeah, but at 103 pages I think we can afford a bit of leeway.
Hadn’t seen enough of this thread, who is having idle issues.
My bike started having minor high idle issues at around 5K miles. Normal seems to be 1000 rpm and I did notice the idle "hang" at 1100-1200 a few times lately. Mostly during cooler temps, and only a temporary/intermittent issue. My bike runs like a Swiss watch and have just not worried much about it.
Idle speed specification is 1100 +- 100rpm
A fluctuation in idle from 1000 to 1200 is considered normal operation?
its still an air/oil cooled bike, dont expect it to be as accurate as a modern watercooled combustion engine upon a 1000th revolution per minute...
weather conditions will certainly affect idle operations
(03-10-2020, 07:25 AM)DBM_imp Wrote: A fluctuation in idle from 1000 to 1200 is considered normal operation?
I'd have expected idle speed to be reasonably constant. The point about popgun's numbers is that provided that constant is in the range 1,000 to 1,200 rpm it's fine. I'd be worried if it's fluctuating wildly even within that range.
^^+1^^
(Sometimes when you see an opportunity to jump on an agreement bandwagon you need to act quickly before such responses become tedious. I am declaring success for myself in this particular instance.)
  idle problem update 1973cb750 37 2,139 05-12-2026, 08:38 PM
Last Post: rdprdp01
  Public Service Announcement - Speed Sensor Clip Gone in 60 7 878 10-22-2025, 02:11 PM
  New speed meter replacement ACE_IRA_imp 3 526 02-13-2025, 06:25 AM
  Idle a little rough and miss fire when revved johnnyH_imp 3 427 09-15-2024, 12:16 AM
  Chain or sprocket problem ? The Gecko_imp 14 1,267 07-30-2024, 10:05 AM
  another idle thread Tom_imp 11 1,017 11-20-2023, 01:30 PM
  O ring chain problem Mixagon_imp 7 664 10-17-2023, 07:28 AM
  TPS Sourcing because of High Idle Obi-wan Kenobi_imp 38 2,744 09-14-2023, 10:08 PM
  Honda CB1100 Rough Idle Solution dickie1951_imp 56 4,295 09-06-2023, 01:36 AM
  About the problem of high idling. (2014 cb1100ex) DDUMZI_imp 62 4,839 08-02-2023, 05:38 PM
Last Post: DDUMZI_imp
