The OBSERVED Valve Clearance thread
#91
oh duh! I should have known that lol
Thanks for posting frulk, i took the liberty to also duplicate your findings in the spreadsheet for valve clearances, they can be deleted or altered if you wish, it's open to the members, just click on a "field", it highligts in blue and you can than type or change the content of that field.
To change values in a field; doubleclick on the field, trundle the cursor to the right place with the left/right arrows and type in new values.
Reason for this spreadsheet is to be able to compare all clearances in a compact version.
https://docs.google.com/spreadsheets/d/1...=473671721
(03-30-2019, 05:41 AM)max_imp Wrote: Thanks for posting frulk, i took the liberty to also duplicate your findings in the spreadsheet for valve clearances, they can be deleted or altered if you wish, it's open to the members, just click on a "field", it highligts in blue and you can than type or change the content of that field.
Thanks max. Downloaded.
Thanks for updating us Frulk. My 2013 is also at 19k miles, never redlined, but ridden “spiritedly”. Based on your clearances and many others, I think I will hold off on getting them checked a bit longer. Bike is running fine and I’m wary to spend that much dough for a non-adjustment. Might do it myself with assistance from from my dad who has the knowledge and shop/tools to do so. Just gotta find the time, we live about 4 hours apart.
It is odd that they cited an adjustment when all your clearances were in spec. I’d be inquiring with them if it were me.
31,000 kms or thereabouts after the last valve clearance check, I've had them done again. The mechanic thought 40,000 kms a reasonable interval for the CB1100.
The clearances are recorded in [url=https://docs.google.com/spreadsheets/d/1oqQaAxkDBnJMwaupL8ctle85ThCTLYdyiFWDyKVbJ3I/edit#gid=473671721]max's spreadsheet and were:
ex: .25 .24 .24 .23 .25 .23 .19 .23
in: .17 .17 .17 .18 .18 .18 .17 .16
Thanks Cormanus, interesting to see what happens over time, appreciate the update.
You're welcome, max. They also gave me the size of the shims currently fitted if that's of interest to you.
Yes please, that complements the research for us all, see if you can insert it just under the new values like; shims used; ........
And just out of interest did you notice any valves ticking before/after?
No, Max, I don't know that I particularly noticed any valves ticking. I picked it up and rode it home about 1.5 kms and wasn't paying much attention. I'll have a listen when I ride it again to see if it is any quieter.
Shims: 192 200 198 195 190 195 195 193
New clearances
ex: .28 .30 .31 .30 .32 .32 .28 .30
Shims: 190 195 193 190 185 190 185 188
This discussion leads me to question my own situation. I generally wear pretty good ear protection and the engine sounds like the proverbial sewing machine all the time. But once in a while I will forget the ear plugs and everything is louder. That's when I notice that under pretty good acceleration I hear distinct ticking from the engine. It runs as it always has with no discernible difference over time. So, is this the injectors doing their thing or valves rattling around? It's got 15k miles on it, mostly casual riding though I do prefer to keep the revs elevated (3500 to 4500 RPM are normal, I guess).
Or maybe I should just put my earplugs back in Angel
  Valve Adjustment Shims dave 13 701 07-28-2026, 12:49 PM
Last Post: MagnaRider
  Valve Adjustment and Camshaft Removal dave 5 626 03-21-2026, 04:49 PM
  Another tire thread: Dunlop TT900GP misterprofessionality 1 363 10-08-2025, 11:57 AM
  Valve Adjustment dave 6 861 08-29-2025, 10:46 AM
  Valve Cover Baffle lining ? bflint 6 939 07-26-2025, 11:27 AM
Last Post: bflint
  Valve Adjustment Intervals CBRider_imp 32 2,886 04-21-2025, 02:24 PM
Last Post: Jurlie_imp
  Another shock thread, but SHOWA JLEECB 17 1,695 02-09-2025, 11:23 PM
  another idle thread Tom_imp 11 1,015 11-20-2023, 01:30 PM
  Valve Adjustment Tolerances - How Far Do You Go? dave 14 1,490 10-18-2023, 09:28 PM
Last Post: The Gecko_imp
  Observed Valve Clearance Cormanus 16 1,443 03-06-2023, 09:03 AM
Last Post: Tejas_imp
