Hi Houtman,Houtman_imp said:Peter , if you need to replace the brake and clutch fluid I would strongly recommend putting Speed Bleeder Products SB8125 SS M8 1.25 stainless steel bleeders on the brakes and clutch . Very easy to do : leave the covers on the reservoirs , take the old bleeder of and put the new ones in AND than remove the covers. VERY little fluid will come out if no air comes in and therefor no mess . Than you can use a vacuum bleeder to get the old fluid out and when you fill up with new fluid before the reservoir is empty than no air into the system . You probably know all this stuff anyway !!!
In the very near future I will have to replace the brake /clutch fluid.
I'll make sure to get them.
Thanks
Alain
