Valve Adjustment
dave
Does Honda recommend that any of the bolts that attach the camshaft holders be replaced when the cams are removed? How about the cam shaft drive sprocket attachment bolts?
Thanks.
No to both questions. The service manual just says to torque them. They are not shown as special bolts in the torque spec section or mentioned as special in section 7 (cylinder heads/valves) in removal and re-installation.
For the cam flange holder bolts it says to put engine oil on the threads and seating surface.
For the sprocket bolts it says apply a locking agent. Book says use medium strength unless otherwise specified. Nothing specified so use medium.
It also shows/says the flange holders must be loosened and tightened in a several steps in a crisscross pattern from outside to inside or they may break. And do not forcibly remove the dowel pins from the camshaft holders.
[quote="Lord Popgun" pid='270542' dateline='1756211313']
[/QUOTE]
Thank you Lord Popgun!
if you need the torque values let me know
