trying to put a tire on for the first time. won't inflate?
My first tire change went the same way. But like anything else it just takes some experience and practice. There are techniques and tools that make the job easier. I heat my new tire by placing a hair dryer inside it while I’m unmounting the old one. It goes on like a soft glove. But it wasn’t until I replaced 3 sets of tires that it became much easier.
By the way there are some great YouTube videos of people going step by step to do many common maintenance procedures. That is how I learned.
lol my friend i think if i attempted 3 sets of tire changes I would die on set number 2. There was a point yesterday where I was just laid out on my back on the garage floor. i literally could not move i was so exhausted. I've walked over 20 miles in summer heat with a backpack, i've moved my entire household on and off a 20 foot truck multiple times in my life by myself, i've unloaded semis full of cabinetry and into rich people's homes, I actually successfully got a honda RLET over a brake lever and i have NEVER done anything so arduous as putting on a rear tire of a motorcycle wheel.
as for the videos....they were kind of the source of the problem. really, it was trying to follow those videos that mislead me so terribly. they make no attempt to explain to you that you absolutely cannot do it without a full size air compressor. they make no attempt to explain the ratchet strap method. they make no attempt to explain to you just how impossibly difficult the levering of the tire over the rim actually is. they just slide the tire on like it's made of neoprene. What i needed was to watch a real person really do it in real life in front of me, then i would have understood all the intricacies before attempting it.
It is important in life to know your own limits , otherwise it will cost you extra money. I hope that you are joking about lying and stealing to take things back to the store because it did not work as expected for YOU . Honesty is always the best way to deal with problems , if not it will back fire badly one day. Always do the right thing in life.
well, thankfully it's online stores, who have a much harder time calling out BS. The correct methodology when returning something is to first attempt to return it without any explanation. Just say "here is your thing back. money please." 8 out of 10 times that will work. Some stores will take a moment and ask why, this is when you come up with a simple and likley explanation. "it doesn't work, it's ugly, it's not as described, it broke when i tried to use it." 1 out of 2 times this will work. finally, every now and again you'll get some busybody that wants to see a picture of how the tire iron was defective. This is when I put it in a vice and bend it real good and send them a picture of that.
either way, i get my money back. got to make the most of your failures, and a key part of that is minimzing the costs through any means necessary.
Here's some fun math on doing your own Tire installs. I'm just adding this to the thread for flavor, now that i've had the opportunity to fully assess the real costs of doing your own tires.
Cost of a Tire swap per set at my local shop: $40
vs.
Cost of basic Tire Irons: $12.00
Cost of Basic rim shields: $13.00 (one time use, so this is cost per tire)
Cost of Air compressor: $140.00 (using the example provided in this thread)
Cost of Tire Lube: $5.00 (i had to use so much of this that i might have enough left to do one more set of tires, so conisder this as 1/2 cost per set)
Cost of Trauma therapy to get over what you went through to lever the tire over the rim: incalculable
Putting the Therapy aside, that's a total cost of $170 for the first try at changing your own tire, and a cost of $28.50 per set for every set therafter.
with these awesome Michelin hoops i change my tires about every 15k miles (estimate) which is a little over a year's riding. This means i'd need to take my wheels to the shop for a tire change for FOUR STRAIGHT YEARS to even approach equivalency with the cost of doing it myself. if you consider that during that four years time, doing it myself would have had me spending an extra $28.50 per year. this means the total cost of self-changing over four years increases to $255.50, so in fact taking the wheels to the shop for a change doesn't even approach the cost of doing it myself. no, if you graph it, it comes to THIRTEEN YEARS before the cost of taking the wheel to the shop overtakes the cost of doing it myself.
that's bananas!! I think the Air compressor (the way things are made these days) would probably even have to be replaced in 13 years, meaning the shop costs will NEVER overtake the cost of doing it yourself. What a joke. I can't believe i was dumb enough to try this.
I’ve been changing my own motorcycle tires for a while now. All the investment in tools has paid for itself. It takes a few times to get the technique down so it’s not such a chore any more. Still takes some muscle power but nothing like the wrestling match the first time I tried it. Getting the bead down in the rim groove is key. Knees and body weight help. Watch the brake disks so you don’t damage them. A good tire changing lube like Bead Butter or Bead Ease is key not only for getting the tires on and off the rim but to make the bead seat more easily. I have a cheap small compressor with a 1 gallon tank and that seats the beads like a charm with the lube. Never had to resort to the strap technique after starting to use lube.
As it is with so many things we choose to do ourselves, rather than paying someone else to do it for us. Generally speaking, for me working on things like motorcycles is as much a test of patience (and a reminder of the tools I might lack or want) as it is anything else. I'm not the most knowledgable of home mechanics and most of the time spent working in the garage is a learning experience. But working on my vehicles has actually been good for me in many ways and at times I'd even say therapeutic. (I sure can't say the same thing about working on my house.)
At the heart of the matter for many of us is that few are likely to pay as much care and attention to our motorcycles (or whatever else people might choose to work on) than ourselves. But ultimately if the interest isn't there and satisfaction is lacking from working on things ourselves then the effort rarely feels like it is worth the time and inconvenience.
Struggling with a tubeless tire is not my idea of fun so I pull the wheel and take it to my friendly dealer.
If I buy the tire there they mount and balance it for a nominal fee and I'm out the door.
misterprofessionality_imp said:
chync_imp said:
You should also lubricate the inside of the rim so the tire won’t stick making it harder to bead. You need to use something that won’t corrode the metal rim. Something that evaporates. And removing the valve stem is a must to get the tire bead to seat. When I do a good job of wetting the rim I don’t need a strap using an air compressor at home. But the tire strap works well.
i used loads of lubricant, believe me. wasted an entire jar of the stuff. its supposed to be specifically for tire mounting. it still took me almost 4 hours to get it into place. probably the most backbreaking, insane thing i've ever physically done. i will NEVER attempt it again.
Stichill_imp said:
lol. being cheap is a matter of survival for my generation. if i wasn't cheap i wouldn't have everything I have. thankfully I'm one year away from owning a home outright, i own my vehicles, i get vacations and work one professional job, and I have all of that because i'm cheap as all heck. i cut corners at every opportunity, lie, cheat, steal, and beg. i will never, ever, ever let one thin penny escape from my pocket if there was any other way to get around it, and it's because of that strength that i've been able to be successful where 75% of my generation has failed.
being cheap is actually what gave me the idea to try to mount this tire. i thought "the shop wants like $40 bucks to mount the tire...the guide says all i need are tire irons, rim shields, lubricants, and an inflator. i've already got the inflator, so that's an easy choice. i can spend $40 on tools right now and never spend $40 to mount a tire again."
yea...what the guides didn't tell me is what you guys are telling me now, that i absolutely have a 3-digit price-range air compressor, that i need to spend another 20-30 bucks on ratchet straps, and what i found out on my own that the rim shields will be totally demolished after the first use. right now i'm trying to make sure that my ignorance doesn't cost me any money. i'm going to tell some lies and return the tire iron tools after this is all over, and never attempt this crap again. clearly it's cheaper just to let the shop do it if you don't already have an air compressor.
jtopiso_imp said:
Houtman_imp said:
You always have a "russian method" for anything, and it's always an effective (and dangerous) one.
[url=https://www.youtube.com/watch?v=vLtBojvDEyc]https://www.youtube.com/watch?v=vLtBojvDEyc
jtopiso_imp said:
If somebody tries it, please make a video :D
that's awesome and gnarly, but needless to say I will not be attempting that. i spent enough money on my tire, i don't need to buy another one.
very cool to watch though. you're not the first person to suggest the fire method to me, but i hadn't actually seen it done before.
max_imp said:
MP, have you tried removing the valve insert and inflating, setting the bead that way like razor mentions
Worked for me last time at the local fuel stop since it allows for more airflow, as soon as it was removed the tire inflated fine.
Once the bead pops on you deflate, re-insert the valve insert and inflate normally.
i do have that valve tool, and i've tried inflating both ways. the gas station air pump had no more success than my home device, but then of course i don't own ratchet straps.
The only option I have at this point is to try to bum some air compressor time off one of the installers that works for me. they might have a ratchet strap too. I don't know yet.
Houtman_imp said:
If you work on your bikes a lot you NEED an air compressor , they will last you a life time if you buy a good one . Even if it means spending less money on up graded parts. Even for house hold jobs an air compressor is very handy : drying , cleaning , staples etc etc.
haha houtman i'm quickly learning what my instincts have always been screaming at me: working on bikes is not for me. Every single time i try something new it ends up like this. nothing ever works like it's supposed to work. it always ends up costing me money. the sole exception to that is when somebody is actively sitting down and showing me what to do step by step, and there's nobody going to teach me how to work on bikes like that.
Bike parts are expensive as heck, so the way I see it, if i make a decision to buy some, they have to go on correctly the first time, without fail, without worry, and without fumbling around trying to figure out what I did wrong. Whatever bike parts i get in the future, they're going to go right to a shop and go on in the hands of a professional, which is the way I always have conducted business up to this point.
Clearly something broke in my brain when i decided i was going to attempt to learn how to do this stuff. lesson learned.
+10 :thumbsup:
Another item to add to the negative side of the DIY ledger: wheel balancer
I'm OK changing dirt bike tires and inner tubes. For street bikes, I'm more concerned about damaging the rims and the tire bead. My local Indian dealer will mount and balance for ~$30 per wheel if you drop off the wheels and new tires.
there we have an even bigger rub, Rocky. "if i buy the tire there." what you'll find at most shops and dealers is that the price of tires is outrageously overinflated. I purchased my most recent PR3 for 128 dollars. my local dealer wanted over $250 for it. sure, they'll mount and balance for a nominal fee....but that $120 difference in tire price is not at all nominal.
+10 :thumbsup:
oh man....if i recalculate on that it's going to be well over 15 years before it equals out. I was just planning to do the "balancing" part by hanging the wheel loose on the spindle on the bike and balancing it by moving around the weight that's already stuck to the bike from previous tire changes. This was the initial advice i read.
Well, at least you gave the tire changing job a shot and won't be wondering whether or not you should be attempting it in the future.
I'm suddenly detecting the irony in your user name. :rofl:
I have a couple recommendations:
- The tire should have a painted yellow dot near the bead , it should be aligned next to the valve stem so the balance is closest and you should need fewer weights. Of course, be sure the direction of rotation arrows are correct.
- motorcycle tires very rarely need a strap to help them bead up. I have one of the inflatable red straps made just for this, and needed it only once in hundred of times (on a car tire).
- If the beads aren't touching on both sides, you will need a large volume of air at moderately high pressure (about 60psi +), so just a small tank-less compressor won't do it. Any car or bike shop should have one.
- If it doesn't bead up, use soapy water or a foaming spray cleaner liberally on the tire at the bead.
- Hold the tire upright, holding the wheel up with one hand and jiggle the wheel side to side against the beads while the tire is filling. The tire should bead up.
As for balancing, you can get very close using the stock axles. Be sure you remove the calipers and any spacers that engage a seal so there is no drag.
My local independent shop will mount tires off the bike for $20 each, while you wait. I buy my tires online and he's more than happy to take my money. For me, it's a no-brainer, but if I had to do it all over again, I should have purchased a No-Mar tire changing machine when I thought about it 25 years ago so I could avoid all of those pesky $20 tire changes (it adds up when you have more than one bike to maintain).
I design, source, and sell cabinetry for a living. If you know anything about the industry, you'd see how important cost cutting is to the entire economy of it. my personal proclivities have served me well. I often end up rather well respected for my ability to make numbers work and put vendors and clients in their place to avoid unnecessary extra costs. well respected *within my industry* that is. vendors and clients come to know me as an insufferable ballbuster.
Thanks for all those Peking. most of those i've covered from the beginning, i did attempt to use soap and lubricants to pop the bead out when attempting to inflate, but there's just no pressure being generated within the tire since i don't have any kind of real air compressor. all the lubricant in the world isn't going to make up for that i don't think.
as for the balancing dot: there was none. I knew of it and i've looked all over the tire for it but it's nowhere. the dot guy at the michelin plant was sleeping that day i guess.
you know what, at approximately $500 flat for the basic version, that's actually much more cost effective than buying all the tools for a manual change (over time) because you don't use up all the consummables like rim shields over and over again. . If one wanted to do their own tires, financially, it seems like that's the only way to go.
Lol we have 13 members of the family with motorcycles, many with several motorcycles. We have talked for years about buying a tire changer and balancer, but never got around to it.
Personally not being comfortable with doing a lot of mechanical stuff, and not having a lift, for me it's just simpler to make an appt, drive my bike up to the shop, walk around for an hour looking at new bikes, and then pay the man and ride my bike home. The same guy has been working on my bikes for quite a few years now. He knows his stuff. It costs a little more to go that route but I know it's done right, I haven't skinned any knuckles, strained anything, said things I probably shouldn't have, or raised my blood pressure, so it's worth it to me.
Yep, that's how I am with oil changes for my car. The dealer sells me a prepaid coupon for 4 oil & filter changes for $100. It's good for twelve months, which works for me. I'd be unable to change my own oil for that amount, and instead of milling around the showroom looking at bikes for an hour, I look at cars.
Must have been on a Wednesday - they use black paint on Wednesdays. :D
The worst thing about taking it to a shop is that it eats up half a Saturday, or you have to arrange dropping off/picking up.
If tires were stack on each other, these will be very difficult to inflate, especially low profile or motorcycle tires due to fact that L & R side beads are touching each other and are too far away from rim's edge.
Home helpful hint: spread tire's beads apart by evenly placing 5-6, wooden 2x2 or 2x4 blocks around, that are about 40% wider then the rim itself. Let it sit spread out for longer time or overnight. Next day remove wooden blocks, lube rim and beads prior installation and you will see how easier is to inflate any tire that is already tightly resting against the rim. Remove inner valve, prior inflation, you need max air flow, not seepage...
I’m tired from reading all this. :D
Somebody is going to have to draw Cormanus a picture...
