Steering Head Shake and Bar Grip.
Pterodactyl_imp
Road warrior
Intrigued by Riko’s post I have done some research on this subject. Rather than broadcast my own rather amateurish opinions, I consulted Keith Code’s “A Twist of the Wrist II: The Basics of High Performance Motorcycling.
‘Who is Keith Code?’, you may ask. Keith Code is a former motorcycle racer, writer, and founder of the California Superbike School. He has been called "arguably the best known and most successful on-track motorcycle instructor in the world”. He knows a little bit more about riding technique than me (insert irony smilie here). I would recommend his book to anyone, regardless of skill level. Never too smart to stop learning and never to late to visit things long forgotten. Let me quote, in part, from Chapter Eight, Rider Input - Holding On:
“…, The overwhelming choice for runner-up in the “unwanted riding conditions” class is: TOO TIGHT ON THE BARS. The same triggers [Code calls them Survival Reactions, or SRs] that cause roll-off/roll-on also fire up this unconscious action. ……"
Continuing, Code says:
"My first inclination is to simply say “relax on the bike”, but because we’re dealing with SRs, it’s not that easy. If there was a way to simply hot-wire (by pass) these reactions, I’d tell you, but there isn’t. But we can handle them, using education as our primary tool. So let’s get smart about holding on.
Machine Demands
Depending on road surface conditions, speed, tires and suspension your bike will head shake, a little or a lot, with some combination of these influences. Any bike will do it. What most riders fail to realise is that this shake is a necessary part of the bike’s suspension system. This system has two stages we can see right away, (1) the tire, and (2) the shocks and forks. The tire handles some of the road’s imperfections because it is rubber and flexes. When it reaches the limit of it’s flex, the shock and fork take over to stabilise the bike. What happens when these two systems fail to handle the situation? The forks move, side to side. They are the next thing to move and they do.
When (1) and (2) above have reached their limits, the immediate result is weight changes to the tires: heavy/light, light/heavy. A spread-out contact patch (when weighting is heavy) forces the forks to turn inwards. When weighting lightens up, the forks seek to return to the centred or neutral position, to track for the lean angle you have. The fork doesn’t quite stop at the perfect tracking position, it goes slightly past it. By this time the tire has hit at least one more surface imperfection and is going through the light/heavy phase again, spreading the contact patch and turning it inwards. That’s what shakes the head.
Stop Shaking
No one is strong enough to stop this from happening. In fact, if you did stop it, the bike would instantly wobble violently and be totally out of control. [My italics.] The good news is that if your bike is basically tight (steering-head bearings not excessively worn, forks and shocks not sticking etc,) the head shake stays up front and does not transfer to the rest of the bike. The bad news is that these head shakes are transferred, back through the rider, after SR#2 [holding on too tight] has kicked in.
………. Hold tight and the bike feels totally unstable and ready to crash; loosen up and it goes straight, even though the front end is working [sometimes imperceptibly] back and forth.”
Code then goes on to explain why holding on tight causes the bike to run wide in turns. Interesting stuff. But back to the wobbles. Code again (his bold):
“….. If everything is tight and your steering damper (if fitted) is working correctly, it only gets as bad as you hold it tight! Remember to relax. Overcoming the “too tight” SR is the hard part. Allowing the front end to “work” is a standard riding technique which agrees with machine design.
Too tight on the bars is the most common source of motorcycle handling problems.”
Donny Greene, five times US 250 GP Champion, comments at the end of the chapter:
“Bending the elbows and wrists instead of straight-arming the bike will set you up to be in a more friendly and relaxed position on the bike. I only vary my grip when I’m making steering changes. Outside of that , my grip is equal and relaxed as I can make it. Treat the bike like a friend and it won’t work against you”
The advice Code and Greene give is real world stuff. When I’m into a long section of twisties and a few of my lines are not what I would want I deliberately loosen up on the bars and ensure that my inside push to counter-steer is only inside of the knuckles, light but positive. Before I apply any counter steer force I consciously relax my outside hand to the point of almost no contact if it is the left and just enough for throttle control with the right. Grip with the knees, eyes on the extended line (look through the corner), weight on the balls of the feet, and lo and behold, problem fixed. Mostly habit for me but if I'm a bit tired or tense for any reason, it has to be done deliberately.
You may have the impression that Code’s book is biased towards the track, and I have to say it is, even though the techniques described therein do translate to the street rider. A good read that is very applicable to street riding is Lee Parks’ Total Control: High Performance Street Riding Techniques. Some say he “unlocks the Code”. He discusses at length a relaxed grip, steering with the inside arm only, and steering “weave”. He says:
“As a motorcycle travels down the road, it actually moves in a nearly undetectable low-amplitude weave, even when the rider thinks it is going straight. ……..”.
“It is my ardent belief that when cornering, you should only use your inside arm to steer. This includes both pushing and pulling when appropriate. ……”
So there it is. Straight from the horses mouth, so to speak. Steering wobble - it’s always there. Good bike condition and a proper riding technique make it our friend.
Both these books are available on internet order in both hard and soft copy. Some forum members have read them. Once again, if you think you would benefit then some schooling at a reputable and appropriate place (Both Parks and Code run schools), and a bit of reading are invaluable tools in the armoury of the serious and safe motorcyclist. I’m a bit long in the tooth (despite my own advice) for track days and try to survive on the road by sheer rat cunning and the occasional glance at Parks and Code. Otherwise I'd enjoy a day at the California Superbike School chasing Ride4now (see his thread) and checking out all that California talent.
Cheers all.
Nice post. Motorcycle riding has been a pleasure for me since the very early 70s, my sisters married riders and got me into riding. Those of us who have enjoyed riding for decades seem to somertimes forget how to explain what has become second nature to us to those who are new to riding. Thanks Ptero.
No worries mate. A lot of stuff like that is not required knowledge to ride a motorcycle. But if you have that knowledge it will enhance the experience and make you a better and, importantly, a safer rider.
Thanks for the post P,
I had 25 years exp. before my first track day. I was 40yrs old when a friend invited me to come along. Had to buy my first 2 piece leather suit. What I noticed was how comfortable a good set of leather pants where and how much easier it was to grab the tank (padded knees) with leathers. Much easier to take the weight off your arms and wrist. Anyone who has owned a SS knows its a matter of survival. I learned more in 5 sessions than in my previous years of riding.
After reading P's post the above was the first thing that came to mind. How easy it is to change your riding style with the proper equipment. Not to mention how much more comfortable, with no seams like jeans and extra padding.
Pterodactyl, I admittedly assume everyone knows this stuff. And that's just wrong on my part.
What I've learned on top of what I learned from reading Code's books is experience (continued learning) plays just as an important roll in one's knowledge base.
In one of the posts (seems to be many right now) about head shake, I simply said 'relax your grip'.
The other person asked if that is counter-active at higher speeds.
And the answer is no, it isn't. It's more important to maintain a relaxed grip.
Actively riding a motorcycle smoothly and in control starts at the body's core.
If you have a weak core, then you can't expect great results.
Some bikes are more forgiving than others.
But the basic principals are the same.
To me, the handlebar is simply the place where the controls are to maniplulate my thoughts into actions. Not a place to hang on too.
I'm not always good at the written word. I also tend to speak my thoughts in the most boiled down form. So if any of this doesn't make sense, no worries.
"In one of the posts (seems to be many right now) about head shake, I simply said 'relax your grip'." soulmachine
Actually there are not a lot of threads or complaints about head shake. I did a search and came up with 5 threads including this one.
CB1100 Forum
One in 2014 a guy complained about headshake at 45 mph while decelerating
One in 2015 a guy complained about a low speed wobble on two different front tires also while decelerating.
One in 2015 a guy complained about head shake when going thru dirty air while passing a truck
One this year where a guy complained about headshake after installing a fairing and a huge trunk.
and this one that talks about riding style and is not a complaint
Let's not make this out to be a big issue when there really isn't one. There is no stability problem with head shake on a stock CB1100
CB1100 Forum
That's the point I was trying to make...
I agree 100%. Its usually rider error. Other small factors could add to it such as not checking tires for propper inflation or over weight bags and packs on the bike and uneven loads. Most people might just not know that its the bikes natural reaction and to not over act and relax. I tell people who get all tense riding in strong wind or rain or over grating on bridges to just relax and let the bike do what it wants to.
All this is enough to make a bloke shake his head in amazement. :P
Thanks for the post, Pterodactyl. Most informative. Refreshers are always good.
For a bloke who reckons he doesn't handle words very well that is beautifully put.
I missed that in my first read. Well said, indeed.
Some of the headshake situations reported do happen to be ones where your survival reactions might indeed coax you to take a tighter grip on the bars, even if unconsciously. I'm looking at you, dirty air from an 18-wheeler. But whatever the cause, I'm firmly in the loose grips save lives school. I'm always aspirin to a loose grip and remind myself along the way to keep me on track. While too tight a grip is always the prime suspect, if your front tire is showing any sign of not being in tip top health, balance and trueness, then kick it to the curb.
