Ulvetanna_imp
Road warrior
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
I was wondering about that. I don't know if the inner weight would fit, the one from the CB500F bars is much longer. I could measure the length and check for you.lash_imp said:Do you think changing the stock weights to the CB500 weights in the stock bars would have the same effect?
Renthals look awesome but vibrate like crazy. As ChipBeck pointed out, the inside diameter of any of the aluminium bars is substantially narrower, so nothing would fit.beardyweirdy@me.com_imp said:I've fitted Renthal Lows or Ultra Lows, can't remember, and love the riding position, but the vibes are too much on long journeys. Esp. as I've lowered the gearing and motorway blasts are too buzzy.
Just wondered, do you think the cb500F bar weights and ends would fit the renthals? I'd need to drill a locating hole perhaps.
Failing that I'll have to go with CB500 bars as well...
Renthals look awesome but vibrate like crazy. As ChipBeck pointed out, the inside diameter of any of the aluminium bars is substantially narrower, so nothing would fit.Ulvetanna_imp said:Renthals look awesome but vibrate like crazy. As ChipBeck pointed out, the inside diameter of any of the aluminium bars is substantially narrower, so nothing would fit.beardyweirdy@me.com_imp said:I've fitted Renthal Lows or Ultra Lows, can't remember, and love the riding position, but the vibes are too much on long journeys. Esp. as I've lowered the gearing and motorway blasts are too buzzy.
The CB500F bars fit perfectly; the color is a match for some of the black found already on at least the '13 Standard, but I'm sure the bar could be stripped of paint and chromed if desired.
My hands are starting to become more sensitive to vibrations, my electric toothbrush actually bothers my hand more than my motorcycle riding. Something about the frequency. So yeah, it comes on kinda sudden and takes forever to heal up or just gets annoyingly chronic. So getting rid of those vibes is a good idea. You'll be in it less than a hundred with the CB500F bars and all the parts for the CB500F weights, internal, external.
You just need to drill a couple of locating holes for the switch gear as ChipBeck has pointed out. Very easy. Flipping the risers forward helps with tank clearance but is not necessary, but you have to be careful about not allowing the bars to hit the tank.:beerchug:
After recalling you are from London and the way you likely use the bike you will for sure want to flip the risers forward. You are gonna love it. BTW if you can retain the four rubber grommets from the CB1100 internal weights, you don't need to purchase those that are spec'd for the CB500F weights. But they do have more contact area and I think it would be worth it just to order them up, because I think this amount of contact area is figured into the engineering. If you lose or damage one those from the CB1100 will work though. It was a little tricky figuring out how they went on to the outer part of the internal weight because there is a clip that locates these weights inside the bar to set them in position but I am very sure you will figure that out without any real headscratching.
Once the RPMs get to 5K, the bar buzz virtually disappears.Hi Mickey, I see it pretty much the same as you, the vibrations really don't bother me all that much. I find your statement interesting regarding how smooth your bike is at 75 mph. I have made the same observation several times on my 2013 model.The ferret_imp said:I find it interesting that some people feel, or should I say are bothered by the vibes in the CB1100. Of course being an inline 4, some vibes are inherent due to motor design, but honestly I just never feel them, at least to the point where they take attention away from the task at hand. Just yesterday I was on the freeway on mine for awhile and remember thinking how smooth it was at 75 miles an hour. Of course on the 6 speed that's still below 4000 rpms, but I don't recall being bothered by vibes on my 2013 5 speed either. Maybe because 5 of my last 6 bikes have been I-4's and I'm just used to them? My V4 seems to have more vibes than my CB.
27,000 on mine now and I agree, what a bike!
Exactly one year later, someone found this thread?Nightengale_imp said:Hmm. Interesting observations.
My '14 standard 'buzzes' in the bars (stock grips / stock weights) at around 3900 - 4xxx (forget, it's winter here) with a annoying vibration. I pulled the stock weights and assembly complete out to learn what was in there. The weights inside the bar aren't that heavy and it appears to me that changing this to a denser material would be worth trying. I also thought about using lead shot inside the bars...
I don't ride fast or in high RPM's most of the time. So just loping along at the posted speed limits (two-lane highways, so 50-60 mph) I get irritated at the buzziness of the bars. It sounds like the CB500F internals and weights would fit the stock bars. I don't want a more forward lean, so I'd not be interested in the CB500F bars, just the weights.
If anyone knows for certain this will work - I'll go buy the pieces. Or try the 1 lb bar weights (where do you find these?)
Also intend to change out the stock grips, they're marginal at best.
Marginal! That's being very kind. I found the Honda grips on my CB500X and CB1100 EX to be miserable. They are too small in diameter and much too hard. My throttle hand would cramp within an hour.Nightengale_imp said:Hmm. Interesting observations.
