Stichill
Road warrior
I was re-organizing my tire repair kit and mini tool kit recently. I decided to take some photos of what's in them. It would be interesting to find out what others are carrying in their kits.
Here's everything as packed on the bike:
The tire repair kit has:[ul] [li]a mini bottle of Slime for slow leaks that can be found/plugged[/li] [li]a Dynaplug mini air compressor[/li] [li]CO2 cartridges in case compressor doesn't work[/li] [li]insulating sleeves for the CO2[/li] [li]a regulator for the CO2[/li] [li]a Stop & Go plug kit with special insertion tool (inside purple bag)[/li] [li]a box cutter for cutting off the outer end of the plug[/li] [li]a digital pressure gauge (I think I will add a mechanical pencil gauge)[/li] [li]a flashlight[/li] [li]cases
[/li][/ul]
Tire Repair Kit
The contents of the mini tool kit are pretty self-evident. Some interesting items are the composite-handle 1/4" ratchet wrench (very light weight), the the very basic stamped-steel ratchet for use with hex bits, the mini vise-grips, silicone rescue tape, electrical tape, double-sided Velcro tape, fuses, and a very thin flat blade screw driver...just because you never know when it might come in handy.
Mini Tool Kit
[/li][/ul]
Tire Repair Kit
Mini Tool Kit
