Mikey350D_imp
First service completed
Got a set of Renthal ultra-low bars (7/8): seeking a moderate cafe look.
I had some concern that they would be too low. i.e. turn signal pod would hit gas tank.
Put bars on today:
Appears they will fit and everything will clear gas tank.
But I had the following problems:
-both the turn signal and starter pods have a pin that fits into a hole in the stock bars, so i will need to drill holes in the Renthals.
-Honda bar-ends do not fit, so I will have to get Renthal bar-ends.
So I put stock bars back on.
I reversed the stock bar mounts, which moves the bars forward about an inch. Felt much better as I am 6'2", now leaning slightly forward.
Looks OK, but if you look closely, you can see the rubber pad between mount and top tree is backwards.
Lessons learned: When disassembling handle bars: There are 2 wires going from brake and clutch cylinder to electrical pods. Disconnect these wires before you remove brake/clutch cylinders. Male tabs bend very easily.
Put bars on today:
