Oil level question
562loosenoodle_imp
I got home from work and put the bike on the center stand. Figured I could wait five minutes and check the oil level. Well after thirty minutes the oil level showed a reading that was below the bottom line. Was the bike too hot to check? Or, am I low on oil. My next oil change is this Saturday. I guess my bike burns oil?
What do you think is going on?
Low on oil.
Not enough info to know if it is burning oil, but most likely not. check around the filter and drain plug for leaks. It may not have been filled properly last oil change.
Definitely low oil if after a few minutes of engine off time. The hot oil flows well in the direction of gravity.
Popgun's suggestions are a great first step.
If you don’t already try to check oil in the same level spot every time. Also, I find I have to top off oil somewhere around halfway between changes. I ride mine a lot at high and low speeds, high and low rpm so I’m sure some oil gets vaporized and burned. Just my 2 cents.
Good point MMC. I agree. If you gobble up RPM, then then some oil will blow by and burn.
I agree, after 30 minutes hot oil would have settled long ago.
Just needs to be topped up I would say.
Good advice from popgun :thumbsup:
Yeah, my oil change is this weekend. It just needed a little. I ride everyday about 70 miles.
My bike gives erratic and inconsistent oil level readings also. I brought this up in a thread a while back. I checked my oil level at home one time and was shocked to see it was low - I knew it shouldn't be low because I had recently checked it. I rode to the shop to buy a quart of oil and when I arrived there the oil level had returned to normal - it had changed from the lower line in the sight glass to the upper line. Bike was on center stand and on level ground both times, and was checked approximately 5 minutes after turning the motor off.
If there is no leak, bike is not burning oil, has no piston blow-by, is always on center stand and you have different oil level readings = you check your oil level at different conditions, i. e : too soon after shut off, not running bike for a while after oil/filter replacement or checking oil level when bike ran cold and too short.
The best and 100 y. o. perfect method is: center stand and next day= cannot go wrong.
* Assume: air cool engine, no fuel interference and I do not believe in engine oil vaporization during normal usage.
Before I start my bike, I have a quick look on the floor if any leak. I check engine oil level between intervals only if I go on very long/multi day trips. Done.
Ride it, do not babysit
I’ve had the same happen to me. Now I only check it in my garage in the same place every time. Make sure it’s hot and sits for awhile before you check too.
I have never lost a mysterious measurable amount of oil on the CB. If you are burning any, inspect the final exhaust ports for oily build-up. Flat black carbon build-up might be present, particularly on cold morning start-ups as condensation works its way out of the cold final pipes. But oil is heavier, shinier spotting at the muffler end. A more direct way is to inspect the spark plugs for oil deposits. The only other way out is a seal leak, but that should be much more obvious. All else being equal, fluctuations in oil level could mean more is stored up in the engine, but I am having a tough time selling that to myself since oil will eventually find its way back to the sump.
Checking it in the same exact place, facing the same direction, is important. What may look level to the naked eye often is not. For example, my driveway looks pretty level, but I get drastically different readings depending on which direction it is facing parked there. It slopes to the right basically.
