oil change help
jay4252_imp
First service completed
Hi
After watching how to do oil change, I decided to change oil today my bike has 700 miles bought the filter and Honda gn4 oil after installing the filter I put 2.5 liter and started the engine for 10 second and then realized I did not put enough oil so I put the whole 4 liter and started the engine for 2 minute and I cannot see any oil in the glass window I have been checking every 5 minute I hope I did not messed up please help Thanks
jay4252_imp said:
Hi
If you put Honda GN4 its sold by the gallon not liters in the US. You want to put the whole gallon ( 4qts) and your good to go. This bike is very hard to get a true reading. You may think your on level ground, reading from one side you can't see the oil turn the bike around the opposite direction and its full. I found a area that reads true after an oil change and check in that spot all the time A gallon of oil will fill the window.
You may be looking at a window full of oil. On my first change I put in the recommended 4 liters. When I checked, I couldn't see any oil. As it turns out, 4 liters will take the level to the very top of the window. The oil is so clean that you can't tell you're looking at oil in the window. I tilted the bike to the left and then I clearly saw the oil level drop in the window.
Another thing you could do is start the bike, let it run for a few seconds, shut it off, then watch the window. You should see the line of oil rise in the window as oil migrates down from the top of the engine into the crankcase.
Thank you so much for all your response, I hope I did not hurt the engine by running the engine for 10 or 20 seconds with only 2.5 liter oil, The dealers here wanted $130.00 for oil change
how to section help it cost only $35.00 dollar
Once again thanks for your help
You can sleep good tonight because there is no way you hurt the engine with over half the capacity in it for 10-20 seconds.
Just a small point I want to confirm, is the bike on the center stand when you checked the oil level?
yes on the center stand a as level as you can get it .....Also that little slotted screw (on the inspection window) is for a wiper blade on the inspection window
Thanks for the reply
Bike is on the side stand , I try but for some reason I cannot put the bike in center stand, but when I did the oil change my neighbor help me put the bike in center stand I rode 20 miles yesterday I checked the oil window still I cannot see anything
Jay get your neighbor to come over and with you laying on your side on the oil site window side of the bike, shine a flash light on the site window, and have him lift the bike vertically to upright and then let it down again to the side stand. You should be able to see the oil rise and fall in the site window. The oil could be below the site window when on the side stand and above it when the bike is standing vertical. New oil is very clean and it might be hard to see. If you put 4 qts in there ( spec calls for 4.1 qts with filter) you should be good. At 4 qts mine was above the window a hair.
See pics below in post 1
How To do your own 600 mile service
Jay I also posted a video which may help you when putting your bike up on the centerstand.
Center stand use can be fun. On this bike I do what I normally do, grab the handlebar and grab rail - one in each hand. With my right foot I'll lower the center stand until it hit the ground. Tilting the bike away from me I'll use my foot to tap the center stand on the ground while tilting to make sure BOTH feet of the center stand are on the ground.
Once I know the stand is properly in contact with the pavement I'll rock the bike back a bit, when the bike is coming back I'll stand on the center stand arm with my full weight and lift the rear a bit with my right arm (while it's tempting to man handle the bike up by lifting with your shoulder; and I get sucked into this mode from time to time, your body weight should be enough to push the center stand down under the bike).
It takes some practice but this bike is easier than many.
And Rboe's way is exactly how I do it.
Just to be sure, you are checking the window when it is NOT running, yes? Once you start it up, you will not be able to see oil in the window.
When in doubt read your manual, it says 3.9 liters, It's on the spec. page 128. You can't see the oil line because you put a little too much in, you can always loosen the oil filter and drain a little out but it ain't hurting anything. 4 liters is = to 1.06 gallons, I often wondered why they set this up to use 4.1 gallons, probably where these are made they use the metric system. I guess that extra QT of oil will last me a long time!
