mjezek_imp
Running like a top
There is already a ton of information on this forum and I wanted to add some pics, technical drawing and written confirmation from our dear friend Jerry at Ohlins USA:
On Mar 3, 2015, at 5:54 AM, Jerry Wohlgemuth <jerry.wohlgemuth@ohlinsusa.com> wrote:
The 362mm length shocks with eyelets at top & bottom would coincide with the ‘HO 010’ & ‘HO 011’ products.
For a ‘piggyback’ version of these shocks you could probably use an ‘HO 414’ (black spring) or ‘HO 417’ (yellow spring) product line. Here is the info:
HO 414: Öhlins shock type S36PR1C1L- rear shocks for Honda CB1300 2003-2011 Pair- black spring: $1530.00 a pair
HO 417: Öhlins shock type S36PR1C1L- rear shocks for Honda CB1300 2003-2011 Pair- yellow spring: $1530.00 a pair
For comparison:
HO 010: Öhlins shock type S36DR1L- rear shocks for Honda CB1100 2010-2011 Pair- black spring: $1085.00
HO 011: Öhlins shock type S36DR1L- rear shocks for Honda CB1100 2010-2011 Pair- chrome spring: $1085.00
I have attached some info. Please call or return email with any questions.
Thank you, Jerry
Jerry Wohlgemuth- Technical Sales Representative-
Motorcycle Division
Öhlins USA, Inc.
703 S. Grove Street, Unit C
Hendersonville, NC 28792
Phone: (828)692-4525 ext. 313
Fax: (828)692-0595
http://www.ohlinsusa.com/us/
info@ohlinsusa.com
On Mar 3, 2015, at 6:26 AM, Jerry Wohlgemuth <jerry.wohlgemuth@ohlinsusa.com> wrote:
The ‘HO 417’ shocks utilize a spherical bearing & separate reducer bushing:
Top: 14mm ID
Bottom: 10mm ID
The ‘HO 011’ shocks utilize a rubber bushing with vulcanized sleeve:
Top: 14mm ID
Bottom: 16mm ID
The top will not be a problem. But you would have to make some kind of reducer sleeve for the bottom eyes.
I decided to purchase the piggyback HO-417 and will deal with the bottom part. Looking at the picture from the "Bad Seeds" you can clearly tell, they just used a bolt and most likely some kind of spacer ... I also have a machine shop at work, which I could utilize, but I don't think so it will be required. Down the line a new swing arm is in order to further reduce weight. ( I think forum member LoLa went this route as well, but not in my budget yet ).
Stay tuned for updates on this channel .. and greetings from sunny and warm California !
For comparison:
Thank you, Jerry
Motorcycle Division
Öhlins USA, Inc.
Fax: (828)692-0595
info@ohlinsusa.com
Top: 14mm ID
Bottom: 10mm ID
Top: 14mm ID
Bottom: 16mm ID
