New speed meter replacement
ACE_IRA_imp
First service completed
Hi there.Just got my oem speed meeter replaced.Have engine pgm fault lights on.Got misfired on high revs as well.Should I bring it to honda garrage to call on new speed meeter?
If you've replaced the original meter assembly with a smaller aftermarket one, there may not be a good solution. Those universal "fit all bike" meters work best on simple singles and twins, primarily older ones.
Several others have done the same before with similar complaints, and we have been largely unable to provide much help, mostly because there is no comprehensive wiring diagram or instructions for them.
You can search our database for similar posts and they may help some. If you replaced with an oem meter assembly, let us know what year you have.
m in sc_imp said:
the ecm sends data back and forth thru the stock gauge cluster to a degree . It's looking for a return signal its no longer getting and faulting out. what did you replace it with?
Its same genuine honda part number.Should I call in new speed meeter ?I ve got engine fault .
Same OEM part—I would read out the fault code if I were you and then we can probably narrow the problem down.
Why was the original meter replaced?
