el duque_imp
Running like a top
I used to be able to post a pic to a forum from imgur but it ain't working like it used to
this is it. sorry.
I have a corbin gunfighter seat to put on it. Nice look but uncomfortable as he**.-shorter bars don't help. Probably only ride it to a vintage rally or two. Its running on points at the moment.
I have a C5 ignition to go in once it appears to be running as it should. If all good I might set it up to take longer rides. It took way too long to get it to this point though.
Still need to sort either a bad spark plug or a carb issue on #4. Runs great on 3 cylinders :excited::excited:
Pulling / installing the carbs on these is so not fun...
tank cleaned and coated.
SS brake lines
upgraded regulator.
all led's except the headlight (I need an option). They all work - that took awhile too.
harley dyna mufflers
carbs rebuilt
alum bits polished
Its not mint - but it fine for me.
I had the Honda decals made. Its got maybe 10 coats of clear.
Painting is/was my nemesis - at least the way I do things.
my basic method was use duplicolor and then coat with a two part K2 clear I found in
an aerosol. Spraymax is the brand. Just like regular automotive, gas resistant clear.
this is it. sorry.
SS brake lines
upgraded regulator.
carbs rebuilt
alum bits polished
